Crew Cab drive shafts
Postby Collers9640 » Fri Jul 07, 2017 10:32 pm
Im gathering parts for my crew cab project. I know that the wheel base is the same for a crew cab short bed and a club cab long bed... So I'm assuming I can use club cab drive shafts... that is if i can find them correct?
Collers9640
Re: Crew Cab drive shafts
Postby simplysmn » Sun May 13, 2018 7:38 pm
No Long Bed crewcab is custom build because of carrier bearing , And what ever trans you are using .
simplysmn
Postby thrashingcows » Sun May 20, 2018 8:07 pm
I had a set of drive shafts from a clubcab 1st gen for my long box crewcab and had to have the 2 pcs drive shaft front piece shortened and the rear lengthened. I since the mount location for the carrier bearing is in a different location on a crewcab. And as Val mentioned depending on what tranny your using you may have to have a different yoke installed.
thrashingcows
Postby dazedandconfused » Wed May 23, 2018 3:35 am
It says he is building a crew cab short bed.
