Project ugly duckling
Re: Project ugly duckling
Postby erroljon » Wed May 02, 2018 12:02 am
Excellent work. Any updates or news?
erroljon
Postby dazedandconfused » Wed May 02, 2018 5:12 am
I haven't done anything to it in years. I drive it every once in a while but it does a lot of sitting.
Postby dazedandconfused » Thu Jul 19, 2018 7:17 pm
Well the transmission finally gave up on it. It's being rebuilt right now. Hopefully I won't have to deal with it again for a long long time.
Postby spencerdiesel » Sun Jul 22, 2018 7:34 pm
Is it getting special stuff or oem rebuild?
Postby dazedandconfused » Mon Jul 23, 2018 4:02 pm
That will include billet front servo, billet accumulator, billet rear super servo, billet 3.8 lever anchor and strap kit, Kevlar low/reverse band, Kevlar 2nd gear band, gpz clutches, kolene steels, custom full functioning VB, Goerend low stall converter.
Postby spencerdiesel » Mon Jul 23, 2018 8:17 pm
Beautiful :D
Postby dazedandconfused » Mon Jul 23, 2018 8:30 pm
I will finally get to see how she will act with a decent transmission.
Postby dazedandconfused » Wed Jul 25, 2018 5:45 pm
I also fixed a axle bearing that was going bad and a seal. Think I'm going to order a new tps sensor and a crankshaft position sensor to see if I can get the computer controlling od.
Postby moparman68 » Sat Sep 15, 2018 9:31 am
How is your 1/2 ton suspension holding up?
moparman68
smoke screw?
Postby dazedandconfused » Sat Sep 15, 2018 10:02 am
My truck is all 3/4 ton front suspension except the spindle, rotor and brakes.
Postby bensol64 » Wed May 29, 2019 1:21 am
Any new mods you did on your truck?
bensol64
Postby dazedandconfused » Sat Nov 09, 2019 5:18 pm
Nope it's parked as I decide it's fate. I bought another half ton in much better shape but not sure if I'm going to put the Cummins in it or a 5.9 gas motor.
