Help with Injection Pump
Postby Collers9640 » Wed Aug 20, 2025 1:38 pm
I have to bleed the injectors every time I shut truck off to get it to start. I believe my injection pump is sucking air.
Is there a certain seal of o ring that could be the problem
Collers9640
Re: Help with Injection Pump
Postby PToombs » Sat Sep 13, 2025 6:14 am
It could be leaking air in a fuel supply line, or at the filter heater. Best way I have found is to pressurize the tank with about 5-10 psi of air and check all the lines looking for leaks. It could be a return line leaking air also.
