New guy,,couple ????'s
Postby thumpertrev » Wed Mar 17, 2010 8:49 pm
I have a 1992 cummins that I will be swapping into a 1994 F350 460 gasser.
Question #1.
If I use the proper fuel pressure regulator, set for 15psi, can I use the factory gasser intank pumps?
Question #2.
My Dodge donor came with the optional tach and I saved all the wiring (saved the whole vehicles harness and ecm). Is there a way to use my Fords indash tach?
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Re: New guy,,couple ????'s
Postby jhedge » Wed Mar 17, 2010 10:35 pm
With the stock lift pump, you shouldn't need the pump in the tank. If you have an easy 15 psi at the tank you could actually skip the lift pump completely, but you may regret that one day. If you have a piston type lift pump, you can get away with running the pump in the tank but not at 15 psi, I'd keep it below 5 psi (measured at the lift pump). I wouldn't recomend putting any positive pressure on a diaphram pump (the stock one for a 92).
jhedge
Postby thumpertrev » Thu Mar 18, 2010 4:57 pm
I was thinking of doing away with the mechanical pump all together and run a return style regulator. I just dont know if the gasser pumps will last using diesel.
thumpertrev
Postby thumpertrev » Fri Mar 19, 2010 7:53 am
Bump on the tach hookup?? Anyone?
thumpertrev
Postby dieseldude » Tue Mar 23, 2010 10:41 pm
Dakota Digital makes an adapter (signal converter) that can make your gas tach. work with your diesel.
92 W350, fuel turned up, pin rotated for full travel, 16cm exaust housing, straight pipe
dieseldude
Postby thumpertrev » Wed Mar 24, 2010 8:43 pm
Thanks, Ill check that out. Just got the Dana 60 under it this last weekend. Want to work out all the bugs in that before it sees more torque from the engine swap. Any idea about using my gasser pumps with a regulator??
thumpertrev
Postby thumpertrev » Sat Mar 27, 2010 8:57 pm
Anyone??
thumpertrev
Postby ozone burner » Thu Apr 01, 2010 11:09 am
i tryed mine on my swap and hated it if it gets cold where you are you will have problems with it.
99 ford superduty 1990 5.9 fass150 pump maxed twins.
ozone burner
Postby 2001FUMMINS250 » Sat Mar 17, 2012 7:06 pm
thumpertrev wrote:I have a 1992 cummins that I will be swapping into a 1994 F350 460 gasser.
Question #1.
Question #2.
#1 fassride.com makes a suction tube kit that u can cancel out your in tank pump And use the lift pump off the engine. The kit comes with instructions. It's pretty simple. I used it on my 2001 Fummins f250.
#2. Ford cummins.com helped me out with wiriing diagram and instructions on hooking up factory tach. Even though I haven't had time to fix mine yet.
Hope that helps.
Jason
2001FUMMINS250
Postby Dieselwrencher » Sat Mar 17, 2012 8:56 pm
For the tach I would get one from Auto World or Destroked. Fordcummins has terrible customer service. On the in tank fuel pumps, ditch them and use the lift pump on the engine. Less work when it fails. But I'd depend on the mechanical pump far more than those electric oe style units.
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
Postby waltzf-n350 » Sun Apr 22, 2012 11:57 am
pics?
waltzf-n350
