1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby spencerdiesel » Sun Jan 29, 2017 5:31 pm
Are those VCO or SAC sticks? Sounds like everyone is really liking the 6x13 who has run them. Keep us posted
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Mon Jan 30, 2017 5:53 pm
They are sac. I just got them so I'll let everyone know how they run!
79Powerwagon
Postby 79Powerwagon » Sat Feb 04, 2017 9:39 am
Just got the 6x13s installed. Took care of my loping issue. Went for a short rip and I'm very impressed. Runs smooth and is very clean until you mash it!!
Really woke it up on top end. Seeing 45psi+ out of the he351 from a stab of the pedal.. Fuel screw was backed out a turn or so from max(this pump won't hit runaway) so there's a lot more in it.
Thanks THD. Now I need a torque converter :P
79Powerwagon
Postby 79Powerwagon » Mon Feb 06, 2017 6:40 am
15x10 steelies...hope they clear :mrgreen:
79Powerwagon
Postby spencerdiesel » Mon Feb 06, 2017 7:08 pm
Could you shoot another accel video :D
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Tue Feb 07, 2017 10:43 am
I can try.... unfortunately the converter slips worse now so it's not a whole lot faster.
79Powerwagon
Postby 79Powerwagon » Wed Feb 08, 2017 6:24 pm
Calipers needed some metal removed... should have a nice stance!!
79Powerwagon
Postby 79Powerwagon » Sun Feb 12, 2017 9:00 am
Too much tire?
79Powerwagon
Postby 79Powerwagon » Tue Feb 14, 2017 4:41 pm
Picked up a sump from Ohio diesel parts. Excellent quality for $55!!!
Ditching the fuel cell and going back to factory tank. Lots of nasty junk to clean out. Thought the fuel sender was a goner but was able to save it using electrolysis with a battery charger to get rid of the rust.
79Powerwagon
Postby PToombs » Tue Feb 14, 2017 5:17 pm
That looks good. What does it use for a gasket?
Postby 79Powerwagon » Tue Feb 14, 2017 5:38 pm
It uses a square shaped oring. Really seems to clamp down well.
79Powerwagon
Postby dazedandconfused » Tue Feb 14, 2017 6:46 pm
That sump looks nice.
Postby 79Powerwagon » Wed Feb 15, 2017 8:40 am
Sender revival. Going to run 1/2" supply and 3/8 " return lines.
79Powerwagon
Postby ellis93 » Wed Feb 15, 2017 12:10 pm
I don't know why but these pictures are huge on this iPhone and only showing the upper left hand corner. Makes following this tread impossible
Postby 79Powerwagon » Wed Feb 15, 2017 2:01 pm
My iPhone resizes them...not sure why that happens
79Powerwagon
