Cummins/82 C10
Re: Cummins/82 C10
Postby RumbleFish » Mon Apr 27, 2015 2:37 pm
Ev= extra valves?
Re: Cummins/82 C10
Postby Tacoclaw » Mon Apr 27, 2015 2:40 pm
Guys got 72 pages and whining about his AIDs thread. You don't want to get 100 pages like I did, Ellis. :lol:
Re: Cummins/82 C10
Postby ellis93 » Mon Apr 27, 2015 3:03 pm
I'm not whining.....I do however like to have ideas shot at me if I'm have problems tho. This tread can die here and now.....if the truck stays going and I don't do anything else to it. That won't happen tho,it isn't running how I think it should. It should have way more power than it does. It's probably just an timing thing now.
Re: Cummins/82 C10
Postby Remps » Mon Apr 27, 2015 9:09 pm
Gov spring and all the free mods are done?
Re: Cummins/82 C10
Postby ellis93 » Tue Apr 28, 2015 3:27 am
All that I can get out of it without looking like the trucks on fire all the time.
Re: Cummins/82 C10
Postby ellis93 » Tue Apr 28, 2015 6:52 am
Apparently my heim joint linkage was hanging up causing the throttle to hang a little while I was adjusting the fuel screw.....I was giving it a piece of a turn and bumping the throttle while running. I've corrected that and found a little adjustment in the fuel 8)
Re: Cummins/82 C10
Postby ellis93 » Fri May 01, 2015 6:37 pm
It's still alive! Making a 230mile trip tomorrow.....wish me luck.
Re: Cummins/82 C10
Postby dazedandconfused » Sun May 03, 2015 8:24 am
Good luck on the trip Ellis I hope it foes good.
Re: Cummins/82 C10
Postby PToombs » Sun May 03, 2015 4:26 pm
Well, he last posted on Friday night, so must be it puked on him. We told him not to paint it that hideous color, serves him right! :lol:
Re: Cummins/82 C10
Postby ellis93 » Sun May 03, 2015 7:16 pm
It did just fine. I've a total of 643miles on it so far,a little less than half of that in one day.
Pete I left the block and head black, and painted the valve cover/intake horn red. What do you want it to be???? Green? :lol:
Re: Cummins/82 C10
Postby PToombs » Mon May 04, 2015 5:00 pm
Glad you made it!
No, it's not going in my truck or Levis so it doesn't need to be green. ;)
Re: Cummins/82 C10
Postby Remps » Wed May 13, 2015 8:44 pm
Any updates? Gonna keep the towing injectors in the hot rod half ton, or put some 6x13's in there? :grin: Those seem to be popular amongst the performance 24 valve crowd.
Re: Cummins/82 C10
Postby ellis93 » Thu May 14, 2015 3:34 am
I'm leaving the stock stuff in it for now. When I do go for some injectors I really have no idea what will work out for me. The stock set I bought off eBay got lost by the usps and I got my money back for them. The plan was to have Eric hog them out and keep the vp pressures.
Hell I haven't even messed with th timing yet.....it still has the the thick shim in the advance spring holding off the timing till later in the rpm range. Making for a soggy mid rpm. It doesn't feel like it comes alive till after 25 or 2600,comparing things to the dodge and its rev characteristics.
Re: Cummins/82 C10
Postby ellis93 » Thu May 14, 2015 7:14 am
Popped a cooler boot this morning......shouldn't have said anything :lol:
Re: Cummins/82 C10
Postby PToombs » Thu May 14, 2015 6:02 pm
You popped it's cherry! Screw it, might's well turn it up now! :mrgreen:
