1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby dazedandconfused » Wed Feb 15, 2017 7:00 pm
Okay you lost me. Why are you running a sump and then a half inch feed out of the factory sender?
Postby Remps » Wed Feb 15, 2017 11:37 pm
Yah pics are huge on my phone, laptop, and work computer.
Postby 79Powerwagon » Thu Feb 16, 2017 3:54 am
dazedandconfused wrote:Okay you lost me. Why are you running a sump and then a half inch feed out of the factory sender?
Sorry that is the return on the sender. I drilled out the original feed and welded that pipe fitting in. Then I crimped off the original return. Both the original feed and return tubes were badly rusted inside. Hose fitting is 3/8" but I just made it so there was room to expand (1/2") if need be.
79Powerwagon
Postby PToombs » Thu Feb 16, 2017 3:55 pm
I asked about the gasket because I have a sump from Sinister Diesel, and the damn gasket swelled up and pushed out. I lost over 1/2 a tank of fuel. :cry:
Postby 79Powerwagon » Thu Feb 16, 2017 4:59 pm
PToombs wrote:I asked about the gasket because I have a sump from Sinister Diesel, and the damn gasket swelled up and pushed out. I lost over 1/2 a tank of fuel. :cry:
What was the gasket on your sump? That would suck.
79Powerwagon
Postby dazedandconfused » Thu Feb 16, 2017 6:03 pm
I gotcha, I was confused for a minute. It's this sump right?
http://www.ohiodieselparts.com/fuel-tank-sumps-1
Postby 79Powerwagon » Thu Feb 16, 2017 7:41 pm
That's the one. Smoking deal IMO.
79Powerwagon
Postby 79Powerwagon » Fri Feb 17, 2017 5:28 pm
Sorry for you guys that can't see the pictures but she looks awesome :mrgreen:
79Powerwagon
Postby PToombs » Sat Feb 18, 2017 10:07 am
It must have been rubber. It came with a black flat gasket, and a tube of Permatex clear silicone. I checked the silicone to see if it was diesel resistant, and the tube didn't say it was. I had the truck parked out back because it was hot so I was running the 2nd gen with AC for about a month. I pulled it up to the garage for something and noticed the gauge was below E, then I saw the wet tank and the dead grass out back. I drained just over a gallon from the sump, I'm surprised it made it to the garage. I cleaned everything, used Permatex black with no gasket, and let it cure for 2 days before I put fuel back in. It's been ok so far.
The truck looks sharp with those wheels. Makes it look like it's ready to go 4 wheelin'! :lol:
Postby 79Powerwagon » Sat Feb 18, 2017 10:59 am
It seems the square oring is a much better design than a flat gasket.
Got the tires cleaned and shined. I think it turned out great. Slight rubbing full turn and they are louder than the engine :sad:
79Powerwagon
Postby dazedandconfused » Sat Feb 18, 2017 7:09 pm
The truck looks good. I'll be ordering 2 of those sumps next week.
Postby 79Powerwagon » Sat Feb 18, 2017 7:26 pm
dazedandconfused wrote:The truck looks good. I'll be ordering 2 of those sumps next week.
Nice. I plan on getting another for the 2001.
79Powerwagon
Postby 79Powerwagon » Sun Feb 19, 2017 12:24 pm
Plow removed, tires clear 8)
79Powerwagon
Postby 79Powerwagon » Sat Feb 25, 2017 8:25 pm
Warlock mission go 8)
And fuel tank/sump install
A lot of work ahead on this stepside bed......northern minnesota rotten.
79Powerwagon
Postby dazedandconfused » Sun Feb 26, 2017 6:57 pm
The step side looks good on there.
