Project "86bt" Chevy Cummins Swap
Re: Project "86bt" Chevy Cummins Swap
Postby T_wilson_3 » Wed Mar 07, 2012 4:52 pm
1STGENFARMBOY wrote:You should be shot for parting that thing out........... OH WAIT ....i'm gettin the rear end. 8)
hurry up and part that truck out. i need some stuff off of it.
Tell ya what.. I'll bring it out to your place along with my Chevy and you can pull the rear end and while youre at it go ahead and pull the motor and put it in the Chevy for me. :lol:
Tory
:grin: head
86 Chevy 4wd cummins swap in the making
91 D350 dd/donor stock
T_wilson_3
Postby T_wilson_3 » Wed Mar 07, 2012 4:57 pm
oldestof11 wrote:I love that body style Chevy!
Ya me too!
You mentioned in another thread about making a cross-member that sits 2" lower and 1" back. You wouldn't happen to have any dimensions or know where to find them would you? I've searched but come up empty. :scratch:
Tory
:grin: head
T_wilson_3
Postby oldestof11 » Wed Mar 07, 2012 5:52 pm
I am trying to remember who told me...
I was going to do a 2wd Suburban of that vintage. I had the engine 1 finger-width (1/2" or so) from the firewall, had the core support cut out slightly for the 1st Gen radiator, and the stock mechanical fan was 1/2" from the radiator.
Postby T_wilson_3 » Wed Mar 07, 2012 5:57 pm
Thats good to know! I was thinking I was going to have to run a electric fan which I still may later I am going to do it right and not cobble it together but I want to spend as little money as I have to.
Tory
:grin: head
T_wilson_3
Postby T_wilson_3 » Wed Mar 07, 2012 6:05 pm
I got my 6" skyjacker softride springs and poly body mounts today!
I'll be in South Carolina all next week and when I get back from that I'm going to hit it hard and try to have the truck driving by may. I'll pretty much just be able to work on it on the weekends.. :x
First thing I'm doing when I get back is tearing down the Chevy to the frame and putting the heavier axles and new springs under it. Then boxing the frame and making the cross-member and getting it all painted up. That'll be a entire weekend project.. Unfortunately I dont have a shop or welder so I'll be dragging it back and forth to work on the weekends..
I cant wait to get started..and finished!
Still looking for a nv4500/np205 if anyone knows where one is.
Tory
:grin: head
T_wilson_3
Postby T_wilson_3 » Fri Mar 09, 2012 8:53 pm
One thing I haven't thought much about but its fairly important.. Is the fuel system. I have a 60 gallon fuel tank tool box combo that is going in the bed and I'm debating just using it and getting rid of the saddle tank. But then I wont have a gauge in the cab just the one made in the tank.. so idk. I may use it as a nurse tank to the stock tank too.
Will a holley blue fuel pump be good? It flows 110gph at 14 psi max and it has 3/8 fittings in and out.
Tory
:grin: head
T_wilson_3
Postby 1STGENFARMBOY » Fri Mar 09, 2012 10:20 pm
If your gonna use an electric pump go with a carter 4160, look at it see what ya think.
Dar
Postby T_wilson_3 » Fri Mar 09, 2012 10:25 pm
Its a little past your bedtime its it?! :jumpsmile:
Tory
:grin: head
T_wilson_3
Postby T_wilson_3 » Fri Mar 09, 2012 10:29 pm
Dar you sure its 4160? I am coming up empty on it. I found a 4601 tho.
Do you think I need an electric fuel pump at all?
Tory
:grin: head
T_wilson_3
Postby PToombs » Sat Mar 10, 2012 7:00 pm
Well, it was past his bedtime and he gets a little dyslexic every now and then, so 4601 may be it. :lol: You don't need an electric one, a piston pump will work good too.
Don't use a holley blue, they won't hold up in diesel.
Postby 1STGENFARMBOY » Sun Mar 11, 2012 9:03 pm
If your gonna crank up the HP your gonna need to up-grade the fuel system with something, idealy a 2nd gen
piston lift pump and a regulator is probly one of the most reliable.
the best performance pump would be an aeromotive A1000 with regulator, but there kinda pricey @ a dab under
$500.00
AH ! ! ! Peter Bartholomew Toombs is corect :mrgreen:
4601= 100gph @ 18psi.
my holly black finally did bite the dust, but only because the brushes wore out, i'm fixen to put in
a new set and put it back on the truck.
is it ideal.....probly not ...but it works well if you can stand the noise.
Dar
Postby T_wilson_3 » Wed Apr 04, 2012 12:07 pm
Well I finally jumped in feet first and started the swap..
It was nice having access to a bridge hoist!
The old small block is getting replaced.
Had to cut the bolts off the exhaust.
Removing the saddle tanks.
Got the axle out.
It sits 4" higher than it did. I'm hoping the weight of the cummins will squat it down a bit.
Cleaning the years of caked on mud off.
Before.
After.
Undercoated the cab.
Looks better without the tanks hanging down. I still have to get the 14bolt in it but my rear springs are still backordered. They should be here around the 20th...
This will be its home for a while. Its a friends garage about 30 minutes from me, beats working outside though!
Tory
:grin: head
T_wilson_3
Postby CumminsPower59 » Wed Apr 04, 2012 12:12 pm
Dang! Looks good! I wish I had that much motivation and a thicker wallet.. :(
Postby T_wilson_3 » Wed Apr 04, 2012 12:22 pm
I'm pulling the motor out of the dodge tonight and hopefully have it in tomorrow night or the next. I have to get some measurements to fab the motor mounts.
Tory
:grin: head
T_wilson_3
Postby Tacoclaw » Wed Apr 04, 2012 6:29 pm
Holy sthi, you weren't kidding about jumping in feet first. :lol: I saw the first pic and expected to see an engine hoist grabbing the gasser out.
It's cool to see someone going all-out like that. I wish I had the patience to do it, but after a few months I just have to drive it again and I start short-cutting things to get it back together...
