Postby 1STGENFARMBOY » Thu Apr 11, 2013 2:24 pm
that means you were ( TIRED ) ... if it makes ya feel any better, it already has stuff I would like to have on my truck.
Postby CumminsPower59 » Thu Apr 11, 2013 3:42 pm
And what's that?? There isn't much useable on that pile...
Postby 1badbirdy » Thu Apr 11, 2013 6:26 pm
Hey Ike, glad to stumble upon this thread! You sure are making progress from the last time I saw it. Glad to see that, keep up the good work! Subscribed :)
TJ
1badbirdy
Postby CumminsPower59 » Thu Apr 11, 2013 8:05 pm
Thanks TJ! Seen pictures of the 92, looks a lot better with the lift and tinted windows :thumright:
Hopefully, I can get the cab removed tomorrow...
Postby 1STGENFARMBOY » Thu Apr 11, 2013 8:10 pm
the G-rag...for one.
Postby CumminsPower59 » Thu Apr 11, 2013 8:15 pm
A Getrag? Na, its got a 727, for now. I am almost done building a NV4500 for it...
I hope the weather dries out and warms up, I got some painting to do...
Postby 1STGENFARMBOY » Fri Apr 12, 2013 8:18 am
well a NV is even better.
Postby CumminsPower59 » Fri Apr 12, 2013 10:09 am
Sure is ;)
Got out of bed nice and early, made some decent progress today...
Got the cab pretty well gutted...
Yeah... there was no saving this cab :|
And an hour later...
Crap :(
Double crap :( :(
The rear cab mounts are a little better, not as much missing material, just cracked right at the outward edge...
So if anyone has a pair or a set of four cab frame mounts, please let me know ;)
Last edited by CumminsPower59 on Tue Sep 09, 2014 9:47 am, edited 1 time in total.
Postby pulltilbroke » Fri Apr 12, 2013 10:48 am
Gives me some motivation to rip my 90 apart and put a cab on it.
Postby CumminsPower59 » Fri Apr 12, 2013 11:05 am
Well, gutting and removing that cab was alot easier than I thought it would be. I will be disecting the cab wiring harness and repairing all the bad parts on it. Going to go through the heater box, clean that guy out. Still need to get some screens for the cowling, and get my buddy with a mobile welding rig to come up and weld the new center hump in (when it gets here) and the tiny little crack at the bottom of the windshield, where they always do. I wish I would have thought to grab those mounts off the donor frame, that thing didn't have a lick of rust anywhere :mad:
I wish it would warm up around here so I can start painting stuff...
Postby ellis93 » Fri Apr 12, 2013 11:13 am
What about using some huge washers to kinda "patch up" those mounts till you find new ones? I just looked under my truck and see no reason you couldn't put them in later.
Postby CumminsPower59 » Fri Apr 12, 2013 11:16 am
That makes sense, I will scrounge around the scrap bin at work and see what I can find...
Postby cmann250 » Fri Apr 12, 2013 12:53 pm
I have a set of cab mounts and 3 of 4 are in good shape. All four are better than the ones you have pics of. I'll have to look and see which one is bad if you're interested.
Postby Philip » Fri Apr 12, 2013 2:19 pm
Ike this is a 1 1/8" flat washer on the rear cab mount on my truck. On my rear mount I had enough of it left to know where the center of the hole was.
I used a piece of 1/4" flat stock on the front mount. I then used a 1 1/4" hole saw to punch the hole threw it. This mount had no way to get a center point from it.
On that front mount I waited till the cab was mounted and squared to the chassis. I used a 5/8" transfer punch to mark the hole from the inside of the cab. I drilled a pilot hole from the top side. Then I used the hole saw from the bottom side.
Postby CumminsPower59 » Fri Apr 12, 2013 2:42 pm
Thanks Philip! I will have to keep that in mind.
