67 Chevy 4X4 Cummins
Re: 67 Chevy 4X4 Cummins
Postby PToombs » Fri Aug 02, 2013 5:51 pm
Well, take it off and use some soap and water. That should kill the squirmy things. :lol:
Postby mad4mudding » Sat Aug 03, 2013 6:20 pm
Got some new pics little fuzzy but not bad for almost dark out
Not proud of the upper hose but that will change. Have a intercooled t-stat housing coming
made the stock alt bracket work on my one wire GM alt
mad4mudding
Postby Knoberman » Sun Aug 11, 2013 7:28 pm
I like the looks of that!
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
Postby mad4mudding » Wed Aug 14, 2013 6:32 pm
Update
installed fuel dowel and 3200 gov spring last week WOW what a diff, really perched it up.
Working on swapping out the t stat housing, different upper hose, now I can run the stock fan too. was just running a small elec one, for the most part runs cool with no fan.
limited time at night makes for a drawn out project some times.
Soon we will try putting the hood back on, although with it off it draws a lot of attention every where I go.
Next on the list is swapping in a diff rear axle with 3:55s something that I have in my stockpile 4:10 are a bit low even with 37s but im not sure if I want 3:55 or 3:73 so we will see how these do on our trip to Maine next month.
mad4mudding
Postby ihredneck » Thu Aug 15, 2013 7:37 am
mad4mudding wrote:Update
An intercooler would help too if you could squeeze one in there...
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Postby thenephilm » Sat Aug 24, 2013 2:54 pm
Looks good, the matching valve covers look great.
thenephilm
Postby mad4mudding » Sun Sep 01, 2013 7:38 pm
Well things look a bit better with the new t-stat housing and upper hose
now there is room for the fan
mad4mudding
Postby mad4mudding » Sun Sep 01, 2013 7:44 pm
A few shots with the hood back on
And yes that's a TDI Everything is DIESEL
Have a bit of everything business and personal, Cat D4H and 312, 410E Deere , two Pete Tri axles with Cats, a 96 powerstroke dump, 2 Duramax pickups, and a VW TDI
mad4mudding
Postby ihredneck » Tue Sep 03, 2013 7:17 am
What tranny are you running in the VW and what's the MPG these days?
2000 VW Jetta TDI
ihredneck
Postby mad4mudding » Tue Sep 03, 2013 3:36 pm
VW is a auto couldnt talk the wife into a stick
it gets high 30s to low 40s. not 50s like the older ones but great power, it will smoke the tires.
mad4mudding
Postby ihredneck » Tue Sep 03, 2013 3:39 pm
Bummer....well life can't always be easy lol! I drove a new Chevy Cruze with the turbo diesel and that little booger was getting 50's!
2000 VW Jetta TDI
ihredneck
Postby mad4mudding » Wed Sep 04, 2013 6:21 pm
Well my 3.55 axle swap was a bust. moved the perches, new cover, new pinion seal. had it all bolted in to find that the drive shaft was about 4" to long, seems that the pinion shaft is a lot longer moving the yoke toward the t-case, axle was a sterling 10.25 out of a 90's ford, just had that shaft built so out it came and back in with the 14bolt. waste of a good day, but I did add to my rear springs to get things leveled up. guess we will see what kind of mileage those 4.10s get on our trip to maine.
mad4mudding
Postby mad4mudding » Thu Sep 19, 2013 5:45 pm
Made our trip to Old Orchard beach Maine last weekend for the car show Got 15mpg with the 4.10 gears in there with limited highway travel, might have averaged 45mph. I starting to think a little more about a OD trans. Its was a bit wet on Thursday and Friday which killed Friday night cruise in on main street, that's always the best part of the weekend. lots of cool stuff that's not at the show. It was a good weekend and a great first road trip.
mad4mudding
Postby ihredneck » Fri Sep 20, 2013 5:46 am
Sounds like OD wouldn't be a bad idea, or a manual swap.
2000 VW Jetta TDI
ihredneck
Postby mad4mudding » Fri Sep 20, 2013 3:13 pm
ya wish I hadn't dumped $2200.00 in that 727 now. could have bought a chevy bell adapter with flex plate and a stand alone control for a 4l80e. I have a friend with a late 90's 4l80e that was just done over then the 6.5 td blew up. guess maybe I should advertise my 727.
mad4mudding
