93oneton 2.0
Re: 93oneton 2.0
Postby spencerdiesel » Sat Jan 09, 2016 8:19 pm
You're gettin it done !
H1C/18
Muffler delete
spencerdiesel
Re: 93oneton 2.0
Postby 93oneton » Sat Jan 09, 2016 9:27 pm
We cut the old frame off rigth infront of the rear mounts and right behind the tranny mount. Pulled it apart the 16" that needed added. We ran 2×2 square tubing down the sides of the frame to make sure it stayed square. Also put legs under the truck to hold it at the same height. Welded it back together inside and out then added fish plates on the back side of the frame. Cleaned the frame up and slapped some under coating on under the cab. Turned out really good i think
In this picture you can see the old section of extended cab frame on the driver side and the crew cab frame on the passanger side
Shit happens
93oneton
Re: 93oneton 2.0
Postby dazedandconfused » Sun Jan 10, 2016 4:57 am
Dam looks good
Re: 93oneton 2.0
Postby PToombs » Sun Jan 10, 2016 9:11 am
I agree with Andy, it looks great! I wish I had a decent shop to work in and the energy to do it.
Re: 93oneton 2.0
Postby 93oneton » Sun Jan 10, 2016 10:01 am
Thanks guys! Im happy with it.
Shit happens
93oneton
Re: 93oneton 2.0
Postby dazedandconfused » Sun Jan 10, 2016 11:06 am
Plan to get it running and driving then worry about paint?
Re: 93oneton 2.0
Postby 93oneton » Sun Jan 10, 2016 11:49 am
dazedandconfused wrote:Plan to get it running and driving then worry about paint?
Yes, i will get it back together then re paint it.
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Sun Jan 10, 2016 5:50 pm
Back home and doors on!
Shit happens
93oneton
Re: 93oneton 2.0
Postby dazedandconfused » Sun Jan 10, 2016 5:56 pm
I dig the silver and grey two tone on the cab.
Re: 93oneton 2.0
Postby 93oneton » Sun Jan 10, 2016 6:32 pm
I think the truck is goin to get painted the dark grey color that is on the cab. Then black atound the windows and hood.
Shit happens
93oneton
Re: 93oneton 2.0
Postby jethro » Sun Jan 10, 2016 9:56 pm
You are doing beautiful work there - and pretty fast too ! I vote for the two tone white/dark grey.
Pretty welds on the frame too ! Not all welds are pretty ! :-)
Yikes- that's not Florida weather !!!!!!
Does you hand break when you accidently hit your hand with a hammer when its that cold ???????? DANG !
Way pretty truck !
Tim
jethro
Re: 93oneton 2.0
Postby thrashingcows » Mon Jan 11, 2016 12:32 am
So you actually added more then 16" to just the club cab frame, correct? You made the cut, stretched the frame out to get the correct wheel base, and then cut out and pasted in the 4' (?) section of crewcab frame?
At least that is how I am seeing it being done. Anyway you did it you sure did a heck of a nice job...and quick too! :D
thrashingcows
Re: 93oneton 2.0
Postby 93oneton » Mon Jan 11, 2016 6:23 am
thrashingcows wrote:So you actually added more then 16" to just the club cab frame, correct? You made the cut, stretched the frame out to get the correct wheel base, and then cut out and pasted in the 4' (?) section of crewcab frame?
Exactly. We added 55" of crew cab frame to the club cab frame, but onluy 16" of wheel base. We did this to get the frame down quicker in The back to miss the floor of the cab.
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Sat Jan 23, 2016 6:06 pm
Cleaned the floor all up. Put some rust converter on a few small spots that had some surface rust on them. Then layed down a nice layer of primer. Then a layer of sound deadening mat. Have bout half done. Still have the firewall and the rest of the driver side to do.
Shit happens
93oneton
Re: 93oneton 2.0
Postby 93oneton » Sun Jan 24, 2016 5:55 pm
Now that the fun of doin that is all done i can order my floor mat and start putting the wiring in it. Still have doors to do put i need to remove the molding from the rear doors and cab, then do the body work.
Shit happens
93oneton
