ellis93 wrote:Also was figuring on how much it'll weigh out....tank and fuel. 60gallons of fuel x 1.8 pounds per gallon is 108lbs, the tank will probably weigh in at another 120lbs,fittings might be a couple of pounds.
cmann250 wrote:ellis93 wrote:Also was figuring on how much it'll weigh out....tank and fuel. 60gallons of fuel x 1.8 pounds per gallon is 108lbs, the tank will probably weigh in at another 120lbs,fittings might be a couple of pounds.
You may want to check yourself. Diesel weighs 7 and change per gallon.
60 gallons x 7 lbs/gallon = 420 lbs You'd be well north of 500 lbs taking into account the tank.
Traction will not be an issue
I'm almost finished with the tank Return to Conversions & Builds
