SUPER CREW!!!
Re: SUPER CREW!!!
Postby randall488 » Fri Jun 07, 2013 9:23 pm
black out the insets of the birdbath hood or a black top?
randall488
Re: SUPER CREW!!!
Postby SuperiorRam » Sat Jun 08, 2013 5:32 am
Updated macho or snow commander design ? I think the black reflective stripes would be sick sh!t
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Re: SUPER CREW!!!
Postby m880cummins » Tue Jun 18, 2013 9:06 pm
Well today I did get to test the starter haha. Cranked over well. I have the alternator on, belt installed, head torqued, valve lash set, injector lines painted and installed, 370 injectors installed with paper thin washers, timing set at 19*, hydraulic lines are custom made and installed for my off engine oil filter, throttle bracket setup fabricated and balancer installed. Engine is almost ready to start. I need power steering fluid, anti freeze, a shut down solenoid, filter head and a turbo. Well definitely have it running early next week! I snapped a picture of my throttle bracket setup. Turned out well and I drilled multiple holes in the bell crank to fine tune the travel and return rate.
Also thinking about running an aftercooler on top of the engine but not sure if I have any space.
Dad also got his cab painted and started assembly to replace the rusted cab on his Cummins M880.
Charlie
SUNY Maritime Class of 2017!
m880cummins
Re: SUPER CREW!!!
Postby rockbuggy4x4 » Wed Jun 19, 2013 10:27 am
Sounds great. Glad to hear it started and run with no problem. But pics aren't showing up? :scratch:
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Re: SUPER CREW!!!
Postby ellis93 » Wed Jun 19, 2013 5:15 pm
Yep.....pics be dead :(
Re: SUPER CREW!!!
Postby BobS » Sat Jun 22, 2013 5:18 pm
ellis93 wrote:Yep.....pics be dead :(
Photobucket now must have a limit on storage.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: SUPER CREW!!!
Postby m880cummins » Sun Jun 23, 2013 1:12 pm
Fixed it. Shelled out the $30 and forgetting about it!
Anyway, no pics but I plan to make a run around Tuesday to pick up my driveshaft, oil filter head and maybe a turbo. I finished the engine bay wiring with relays for the starter and shut down solenoid so I keep the load off the ignition switch. I don't like amperage in the interior area.
Charlie
m880cummins
Re: SUPER CREW!!!
Postby PToombs » Sun Jun 23, 2013 5:44 pm
$30 for what? Photobucket? Or did I miss something?
Re: SUPER CREW!!!
Postby m880cummins » Sun Jun 23, 2013 6:48 pm
$30/yr for unlimited bandwidth and 20gb of uploads. I'm good now... Probably only have to pay once because it's dependent on how much you use photobucket. I won't be using it much after this truck is done.
Charlie
m880cummins
Re: SUPER CREW!!!
Postby PToombs » Mon Jun 24, 2013 4:10 pm
Ah, I see! I use it in spurts, 3 or 4 pics, then nothing for a few months.
Re: SUPER CREW!!!
Postby m880cummins » Thu Jun 27, 2013 12:25 pm
Getting down to the nitty gritty now! Got my ignition switch wired, ground wires done, shut down solenoid wired with relays for it as well as the starter, alternator wiring done and everything wrapped together and cleaned up. Last night I was getting ready to put the AFC on the pump and noticed my rack is seized up again. Figured it would have to be rebuilt so I figured I'd try to free it up myself. I took each DV assembly out and marked the positioning as well as shim thickness so flow CCs are close and then cleaned out the pump and used a sharpie pen with 1000 grit paper to clean up the plunger barrels. Cleaned them really well and then lubed them with ATF. Rack moves better than it ever did now. Fuel lines are done and turbo is coming this weekend.
Charlie
m880cummins
Re: SUPER CREW!!!
Postby PToombs » Thu Jun 27, 2013 6:23 pm
I like a well lubed rack myself! ;)
Re: SUPER CREW!!!
Postby m880cummins » Thu Jun 27, 2013 6:33 pm
Your perverse comments will never get old :lol:
m880cummins
Re: SUPER CREW!!!
Postby PToombs » Thu Jun 27, 2013 6:38 pm
Thanks buddy! :jumpsmile:
Re: SUPER CREW!!!
Postby dazedandconfused » Fri Jun 28, 2013 4:45 am
PToombs wrote:I like a well lubed rack myself! ;)
I have to agree with you on that! :mrgreen:
