Postby Mark Nixon » Fri May 31, 2013 7:16 am
No carpet?
Trying to get it together at least in "hooptie" fashion, eh?
Postby CumminsPower59 » Fri May 31, 2013 8:11 am
You got it Mark! Bare minimum, not only to possibly get it to Michael's, but I need it for the weekend after, as I bought another house and we will be moving then...even though its four blocks away :lol:
Postby Mark Nixon » Fri May 31, 2013 8:36 am
Wow.
Movin' on up? To the east side? Deluxe apartment in the sky? :lol:
Postby CumminsPower59 » Fri May 31, 2013 11:31 am
Crap :(
Last edited by CumminsPower59 on Tue Sep 09, 2014 10:25 am, edited 1 time in total.
Postby Mark Nixon » Fri May 31, 2013 12:13 pm
Hard to see what you're "crapping" about?
Looks a bit gummy, but that should clean up if you totally dis-assemble it.
What's wrong :?:
Postby CumminsPower59 » Fri May 31, 2013 12:41 pm
Gummy is right...things were a bit stuck, there was a good amount of water in it too.
Postby RCCUMMINS89 » Fri May 31, 2013 1:05 pm
That thing looks straight up NASTY
Postby CumminsPower59 » Fri May 31, 2013 1:29 pm
It took a fair amount of force and wiggling back and forth to get the KSB piston free, it was froze in place. The bore that it rides in is quite scored...gonna clean it the best I can and slap it back together...
Postby CumminsPower59 » Wed Jun 05, 2013 11:59 am
Progress!
Got the IP resealed and put back on the engine, KDP peened over, checked the case bolts I could get at, all snug :mrgreen: Finished painting the front half of the truck, installed doors and the passenger fender. Got the steering column in, found my stock steering shaft to be too short, now I need to get a U-joint so I can re-use the old Borgeson shaft I have. Got most of the dash wiring harness in, got to run the door/speaker harness.
Pics to come in a minute..
Postby CumminsPower59 » Wed Jun 05, 2013 12:14 pm
Last edited by CumminsPower59 on Tue Sep 09, 2014 10:27 am, edited 1 time in total.
Postby dazedandconfused » Wed Jun 05, 2013 12:22 pm
Looking good.
Postby RCCUMMINS89 » Wed Jun 05, 2013 12:24 pm
8)
Postby redneckroot » Wed Jun 05, 2013 1:06 pm
Looking good.
redneckroot
Postby Mark Nixon » Wed Jun 05, 2013 1:12 pm
Ah, sweet noticeable PROGRESS! :D
Postby CumminsPower59 » Sat Jun 08, 2013 11:18 am
Well, it's alive. Long story short, hooked a battery, grounded this, put power to that, and a phone call and it starts. It ran like absolute crap for a while, then it finally has a smooth idle. Now...it runs smooth up to about 1500 rpm's, then kinda falls flat on its face...push the throttle more, and it stays at a constant rpm...
Hmmmm.... :?:
