Jon's build thread
Re: Project: p-pUmp This!
Postby Sutter1stgen » Sat Mar 30, 2013 6:41 am
Gut it and paint the frame rails. It would go with the budget theme, and look good painted. Id remove any cross members that aren't being used (spare tire, t-case skid plate). Find a couple junker factory bumpers and take a hole saw to them.
All this talk of putting the truck on a diet has me thinking, maybe I could lose 50 or so pounds to help out.
Eric
Sutter1stgen
Postby oldestof11 » Sun Mar 31, 2013 11:57 am
The only cross member i would feel safe removing is the one the spare tire and shocks mount to. Going custom shocks with it being lowered.
Just ordered a lift pump from Eric. Excited to install it!
Postby oldestof11 » Tue Apr 02, 2013 2:48 pm
Just picked this up for $100.
11 gallon, fuel sump with 2 -8AN fittings, -6AN fuel return, and brackets. Poly construction
On the (e)Bay, it seems something like this without brackets is around $150.
Postby CumminsPower59 » Tue Apr 02, 2013 8:07 pm
I call dibs on your stock tank if you want to get rid of it :lol:
Postby RCCUMMINS89 » Tue Apr 02, 2013 8:28 pm
What size injectors are going to get?
Postby oldestof11 » Wed Apr 03, 2013 4:00 am
Sure Ike!
Eric, something conservative right now. Going for cheap more than anything. Either PODs (yuck) or 375s.
Postby RCCUMMINS89 » Wed Apr 03, 2013 8:03 am
370s are a cheap injector.
Food for thought. My builder tells me to use a marine 350 over the 370. They flow exactly the same on his flow meter, both are a 5 hole sac..... yet he says that the 350 always seem to chatter better "out of the box". He still doesn't know why but about 10% of the 370s out of the box leak and he usually has to clean or do something to them.
There is also a 5 hole VCO nozzle that is the same size, that I'm actually going to try here by next week. yes the 155 angle..... but I'm hoping with the right washer and I've had 8 thou milled of fmy head that I can keep it in the bowl. I'm having it opened up to the DDP comp size of 70-72ish lpm.
Postby oldestof11 » Wed Apr 03, 2013 3:45 pm
Ideally, i want a non ic engine so i can run the biggest injector with lots of timing. Ideally....
Postby cmann250 » Wed Apr 03, 2013 6:17 pm
oldestof11 wrote:Ideally, i want a non ic engine so i can run the biggest injector with lots of timing. Ideally....
Straight up truck trade? I have the non-IC engine, the auto, and the Mopar light weight "racing" package already. :lol:
Postby oldestof11 » Wed Apr 03, 2013 6:55 pm
Uh no. I don't want the 727 or weight savings courteous of nature. :lol: i looked hard for this near rust free truck.
Postby PToombs » Thu Apr 04, 2013 4:22 pm
And now you're going to cut it up? :roll:
Postby oldestof11 » Thu Apr 04, 2013 4:59 pm
When i said hardly, i meant very little. Aka the bed. Multiple holes and inner giant one for the stack. The left rear corner was about rusted through.
Postby oldestof11 » Fri Apr 05, 2013 2:28 pm
Giggity! Thanks Eric!
Postby RCCUMMINS89 » Fri Apr 05, 2013 2:45 pm
Let me know how the install goes..... I'm putting in my new sticks right now..... but it's friggin raining now
Postby oldestof11 » Sat Apr 06, 2013 6:12 pm
So today i drive this
To find what's left of this
