Postby CumminsPower59 » Wed Dec 11, 2013 6:39 pm
Its not too far off then...grabbed the flat bar out of the garage, works well wedged under the throttle pedal, kick it up to 1100-1200 rpms for warm ups and what not...
Postby CumminsPower59 » Thu Dec 12, 2013 12:57 am
This is after 30 minutes at 1100 rpm...
Crap :(
Last edited by CumminsPower59 on Tue Sep 09, 2014 11:36 am, edited 1 time in total.
Postby 1STGENFARMBOY » Thu Dec 12, 2013 9:44 am
Are you getting the feeling you wish you were still driving buy the guys field and saying......hey see that ol red truck out there, it used to be mine.
I have been where you are with old trucks and it ain't a fun place....sorry dude.
Last edited by 1STGENFARMBOY on Thu Dec 12, 2013 11:51 am, edited 1 time in total.
Postby ellis93 » Thu Dec 12, 2013 10:13 am
Valve stem seals......? I wouldn't have thought mine were bad till I pulled the head. There was oil in the exhaust port of number 5.
Postby PToombs » Thu Dec 12, 2013 5:26 pm
Ike, do you have a different turbo to throw on and try? That would tell you right away if it's the turbo or not.
Postby ellis93 » Thu Dec 12, 2013 5:34 pm
PToombs wrote:Ike, do you have a different turbo to throw on and try? That would tell you right away if it's the turbo or not.
How would that run upstream into the manifold? Surely the scavenging effect wouldn't pull fluids into there :scratch:
Postby PToombs » Thu Dec 12, 2013 5:39 pm
I missed the pic with the oil running out of the manifold. :oops:
Postby bgilbert » Thu Dec 12, 2013 6:44 pm
Or run the engine with no turbo bolted to the manifold ;). Maybe you just need to get out and work the engine real hard to clean up/out the cylinders. Get it good and warm. I've heard and experienced an engine spit/leak oil due to inactivity or prolonged periods of idle time and cold weather operation not allowing the engine to reach operating temp.
Bill Gilbert
bgilbert
Postby CumminsPower59 » Thu Dec 12, 2013 6:48 pm
Lately its been about 0 degrees here, so the block heater is being used, but I thought about reducing the warm up idle time to 5-10 minutes instead of 30+...
Postby RCCUMMINS89 » Thu Dec 12, 2013 8:03 pm
Long idle warm up times is very hard on our trucks.
The faster it can get up to temp without working it hard the better. I drive mine as soon as it will idle normal, I then just drive it VERY easy until it has reached full operating temperature and the thermostat has opened....twice. I then treat it like it's a Ferrari.
Postby CumminsPower59 » Thu Dec 12, 2013 9:17 pm
Speaking of warm up...this is what my truck does several times when going down the road...
It'll go from this
To this
And then back down pretty fast...air pocket? It never did this with the el cheapo thermostat, it has a Cummins thermostat now...
Postby RCCUMMINS89 » Thu Dec 12, 2013 9:23 pm
Mine does the same fricken thing..... I think it is air in the system. Mine does it if the thermostat closes for a while. I think I'm getting air in the system somehow and it gets pushed up to the thermostat and therefore the thermostat doesn't work correctly.
Postby CumminsPower59 » Thu Dec 12, 2013 9:28 pm
Aaannnndddd.....its leaking coolant again. I keep tightening the clamps, but for some reason, it keeps leaking....
Postby ellis93 » Fri Dec 13, 2013 4:19 am
Ike pull that thermo and take a pair of side cutters to those brass air bleeds in the flange. Cutting those out will allow water to slowly flow past the thermo and let it heat up faster.....stopping that wild swing. Only problem with doing this is sometimes it take a little longer for the engine to come to temp.
This will also let it burp any trapped air because you will always have water passing the thermostat.
Postby CumminsPower59 » Fri Dec 13, 2013 10:23 am
Sounds like a plan. The thermostat I got from Tim Worline back at SOP 8 had three brass bleeds on it, and it was a Cummins unit. The one that I bought this time only has two...but I'll cut 'em out.
