CumminsPower59 wrote:Has anyone found a definitive solution to these "lights pulsing" issues?
TheSilverBullet wrote:Glad to see my 5 speed went to a good cause. Did you sell it? Details on the samurai
cmann250 wrote:CumminsPower59 wrote:Has anyone found a definitive solution to these "lights pulsing" issues?
What do your battery cables look like? I think I accidently fixed my issue when I went to new cables. I also went a size heavier on all the leads coming off of the cables and the cables themselves are now 2/0 ga.
I have my headlights on relays and my voltage regular is the higher grade from O'Reilly's.
I just went out and turned them on to check. I don't think they pulse anymore. They were bad about pulsing previously. I nearly gave you and Jake a seizure at SOP
CumminsPower59 wrote:Bill, I didn't rebuild that case, just looked it over inside and out and ran it. It seemed really tight.
CumminsPower59 wrote:As long as I got four wheel drive for Tuesday, as 18-24" of snow is forecasted....
bgilbert wrote:CumminsPower59 wrote:Bill, I didn't rebuild that case, just looked it over inside and out and ran it. It seemed really tight.
Nixon case eh?![]()
