Project ugly duckling
Re: Project ugly duckling
Postby CumminsPower59 » Mon Sep 23, 2013 5:58 pm
Either way, looks good. I noticed that you don't have steering column covers, do you need some? I can bring some to SOP if you want...
Postby dazedandconfused » Mon Sep 23, 2013 6:01 pm
I think I have them just don't have the stupid little screws for them. I have sthi laying all over.
Postby CumminsPower59 » Mon Sep 23, 2013 7:30 pm
Ah, right on. I do have them too, if you need them...
Postby dazedandconfused » Fri Oct 18, 2013 5:35 am
So Ive been fighting the urge to convert the duck to 4x4. I don't really know why I guess I'm just bored and need to tear it apart again lol.
Postby ellis93 » Fri Oct 18, 2013 6:49 am
dazedandconfused wrote:So Ive been fighting the urge to convert the duck to 4x4. I don't really know why I guess I'm just bored and need to tear it apart again lol.
You need to go find a woman,they'll fill your time :lol:
How's the trans
Postby dazedandconfused » Fri Oct 18, 2013 9:40 am
Oh the trans hates me. Lol I was going to take my 47rh slip yoke and have a shaft made but apparently its different since it won't slide into the 518.
Postby dazedandconfused » Thu Nov 21, 2013 2:10 pm
So I ate another one of those dam conversion joints today. I bought a cheap u-joint and used the caps to try and get bye. I don't know what's up with those dam caps splitting but the cheap ones I replace them with last.
Postby cmann250 » Thu Nov 21, 2013 4:29 pm
I can hear that little brown truck screaming from here that it wants a 47RH.
That conversion joint is clear at the back isn't it? I'd think it'd be 1410 at the slip yoke and then 1410/???? at the axle. I just looked and found a 1410 yoke for the 9" doesn't exist which I think is strange.
Postby dazedandconfused » Thu Nov 21, 2013 4:40 pm
Yeah its at the rear end. Its a 1410/1350 conversion joint. I was told by the company I got it from I just have to much power for them.
Postby ellis93 » Thu Nov 21, 2013 4:46 pm
dazedandconfused wrote:Yeah its at the rear end. Its a 1410/1350 conversion joint. I was told by the company I got it from I just have to much power for them.
Sounds like a pussy joint to me. Can you find another manufacture of this style bastajoint
Postby dazedandconfused » Thu Nov 21, 2013 4:48 pm
Nope they are the only ones I found making them.
Postby dazedandconfused » Thu Nov 21, 2013 5:05 pm
After using my brain a little I figured maybe I'll go to the junkyard and try to find a shaft out of a Ford to be modified to fit my truck.
Postby PToombs » Thu Nov 21, 2013 6:36 pm
Don't you have a ford sitting in the yard? :mrgreen:
Postby ellis93 » Thu Nov 21, 2013 6:44 pm
I did that with the 82. I found the dodge shaft would slide over the Chevy stuff,but had some slop to it. The slop I took out by wrapping the Chevy shaft with 2" wide electrical tape every 4" down the length of it,then slid it inside the dodge shaft. I cut both shafts really long so I knew that would keep them straight,lined up the yoke ears,and welded it out. The few times I've driven it(up to 60mph) it didn't vibrate.
Postby PToombs » Fri Nov 22, 2013 5:52 pm
And there went my opinion of your skills again, fell right off the scale. :( I think you need to move to Kentucky with the rest of them......... :lol:
