Project ugly duckling
Re: Project ugly duckling
Postby matthewh » Mon Mar 17, 2014 4:13 pm
You can test everything, but my moneys on booster. My '93 did that, abs/brake light on, sporadic hard pedal. Ended up the booster was leaking into the cab. I did replace the pump too, as it was putting out the bare minimum at the test port, and the hose was good
matthewh
Postby dazedandconfused » Mon Mar 17, 2014 4:30 pm
Booster and master aren't that old but they are reman units.
Postby matthewh » Mon Mar 17, 2014 4:39 pm
Possibly the pump then. Won't know till ya put a vac gauge on it and yedt everything.
FYI, I found while working on mine, standard vac hose doesn't have enough arse to hold up. I replaced the main line from pump to booster, collapsed as soon ad I started it. Ended up swapping a better hose off a parts truck, as my original was checked and leaking
matthewh
Postby dazedandconfused » Thu Apr 10, 2014 4:48 pm
I decided to dig my old grille out tonight and see what it will take to make it work. looks like a little trimming and moving my headlights down will be in order.
Postby oldestof11 » Sat Apr 12, 2014 11:25 am
Time for hydroboost?
Postby DMan1198 » Sat Apr 12, 2014 6:16 pm
Hydro boost would be good
Postby dazedandconfused » Sat Apr 12, 2014 6:40 pm
I've never had good luck with the GM hydro boost. Mine works unless I'm in traffic on and off the pedal a lot it will get hard.II'm pretty sure its the booster.
Postby DodgeFreak » Mon Apr 14, 2014 9:37 am
if you towed alot or needed alot of braking i'd say hydroboost but for what you are using it for a vaccum booster will be just fine and alot less hassle.
Postby RumbleFish » Mon Apr 14, 2014 6:23 pm
I have a dodge boosterbi bought from ike. And coolertubz i bought from philip to clear it. If i could figure outbhowbto mount it id put it on. Im no fabricator lol
Postby CumminsPower59 » Tue Apr 15, 2014 10:20 pm
You still don't have that stuff on yet?!?!
Postby dazedandconfused » Wed Apr 16, 2014 9:24 am
Don't be scared Jeff
Postby ellis93 » Wed Apr 16, 2014 11:17 am
Nothing to it but having the necessary tools, even without a few it can be done. Come on guy.....don't be a puss :lol:
Postby RumbleFish » Wed Apr 16, 2014 12:23 pm
Its not so much that im scared, just cant afford to have the truck down. Im sure it wont be an evening install. And it wlnt fit in my garage so I had to wait for nice weather to do it outside. I did score a pump with the extra fitting. I think I just need hoses and do something with the pushrod. Have I mentioned I cant weld?
Postby ellis93 » Wed Apr 16, 2014 12:41 pm
Can't weld? Do you have "friends" that can? :lol:
Postby RumbleFish » Wed Apr 16, 2014 1:46 pm
My dad is decent welder. But if I have him do it Ill have 900 questions about what Im doing and why and why cant I leave it alone etc.
