1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby 79Powerwagon » Tue Apr 05, 2016 9:37 am
Talking with THD. Wondering about DAP 6X13s vs bosch.
79Powerwagon
Postby 79Powerwagon » Tue Apr 05, 2016 3:44 pm
Rolled on and put it to the board. Broke traction when the boost spiked to 30 psi :lol:
https://youtu.be/X55f7KYK5ME
79Powerwagon
Postby spencerdiesel » Wed Apr 06, 2016 3:28 am
Nice!!!!! Renews faith in the VE. After my friend got injectors and a 66mm for his OBS, it would brake loose at a 25 roll. This is good :lol:
Are the aftermarket bodies available from THD DAP's?
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Wed Apr 06, 2016 4:38 am
spencerdiesel wrote:Nice!!!!! Renews faith in the VE. After my friend got injectors and a 66mm for his OBS, it would brake loose at a 25 roll. This is good :lol:
I know it. Exciting to see how well it runs with stock injectors. Can't wait to go bigger.
Yes they are through thd.
79Powerwagon
Postby spencerdiesel » Wed Apr 06, 2016 6:53 am
You going to take 3 or 4 turns out of the screw when the new sticks go in? So you get a reference point?
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Wed Apr 06, 2016 7:21 am
spencerdiesel wrote:You going to take 3 or 4 turns out of the screw when the new sticks go in? So you get a reference point?
Sounds like I'll have to , to keep smoke and egts down with the single charger.
Itd be nice to dyno now to get a baseline.
79Powerwagon
Postby spencerdiesel » Wed Apr 06, 2016 8:10 am
I'm curious to see how many turns you'll have to take out with the new sticks to run the same as the stock sticks with the pump maxed
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Sat Apr 09, 2016 10:50 am
Started on the gauge pod. Have boost and drive pressure. Egt on its way. Think I'll add fuel pressure eventually.
79Powerwagon
Postby 79Powerwagon » Sat Apr 09, 2016 1:31 pm
Really didn't like how the pod looked on top of the dash. So I abandoned that and mounted them in the dash.
79Powerwagon
Postby 79Powerwagon » Wed Apr 13, 2016 4:43 am
79Powerwagon
Postby 79Powerwagon » Fri Apr 15, 2016 6:17 pm
Poor man's Cali dump exhaust.
https://youtu.be/qE4H9aW7T3E
Stack was making me lose my hearing.
79Powerwagon
Postby spencerdiesel » Sat Apr 16, 2016 8:59 am
My friend (same one with the OBS) had a cat stack like you did.......and for about the same amount of time you did too :bom:
Sweet burnout
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Sat Apr 16, 2016 5:44 pm
Powerwagon, did you have any real issues putting the cummins in that truck? Friend of mine bought a '78 club cab he is going to put a 5.9 and NV4500 into so I thought I'd ask.
Postby 79Powerwagon » Sun Apr 17, 2016 5:50 am
Engine bolts in. Trans mount may have to be modified, mine did. Had to slot the mounting holes. Driveshafts need modified.
I used the 93 core support so I could use the 93 radiator and intercooler. There are 4 tabs on the 79 for the lower fender/grill valance that I cut off and welded to the 93 cs.
Wiring is pretty simple.
You do need to make sure the front leaf packs are up to the task. This truck had six leaf packs and it's holding up pretty well. 3/4 ton axles are ideal.
These old trucks really don't have any sound deadening so that's something to consider also.
79Powerwagon
Postby 79Powerwagon » Sun Apr 17, 2016 5:53 am
I also hear that the 1/2 frame may not be strong enough especially if your putting a good amount of power down. Mine seems to be holding up well, but boxing it and building heavier x-members isn't a bad idea.
I'll run mine hard til it breaks.
79Powerwagon
