Cummins/82 C10
Re: Cummins/82 C10
Postby cmann250 » Mon Apr 28, 2014 7:04 am
I turn 1500 at 60 and 2000 at 80 with 3.07s, so says math.
If those numbers are locked in O/D, the math is pretty straight forward. Locked in direct would be even easier. I vote the 3.0x that you thought it was before.
Re: Cummins/82 C10
Postby ellis93 » Fri May 02, 2014 6:21 pm
Well I bought the seal and GL5 to heal up the pinion leak,true to the nature of my life I had no time to dig into the rear end to check the gears.
Caleb I checked my tach against a borrowed test tach and it was off some,refigured my tach and the rpms are almost dead on what you said. I've gotta have 3:08s ( chevy's favorite truck gear)
I'd have said the were lower just from the sound of the engine, it makes twice as much racket as the dodges cummins. Is that a p pump characteristic? :scratch:
Checked the mileage again, not so good this time. Got 21.8 this time. I guess I was mashing harder on it or something. :?
Re: Cummins/82 C10
Postby dazedandconfused » Fri May 02, 2014 6:42 pm
I still want to go yo a 3.00 gear or closed. With my 3.25 gear its equivalent to 3.55 with my tire size.
Re: Cummins/82 C10
Postby ellis93 » Fri May 02, 2014 6:55 pm
As is,what kind of mileage are you knocking down Andy? I think I asked before but can't remimber what it was :)
Re: Cummins/82 C10
Postby dazedandconfused » Sat May 03, 2014 4:24 am
I'm at 17-18 now with my fuel system issue and a very loose trans. Its shuddering bad when I stand on it taking off.
Re: Cummins/82 C10
Postby ellis93 » Sat May 03, 2014 6:49 pm
Well the wife and I went to Mobile Al tonight for dinner and loafing around in the 82. Got several WTH looks 8) and one challenge at a red light. Being I had the wife in the truck and not knowing if I'd tear it up,I passed. Then two lights latter the same @ss was revving his OBS Caleb special at me,puking smoke all over my truck......I took it :lol:
He'd have wipped me if he wasn't grinding gears in that zf5 ( oh....wait, that's just how they shift :lol: )
I might have got him but not without cost.....seems I broke an engine mount. The motor has settled on the pass side and it is throwing some massive vibs out. Dang it :( I knew better :)
Now to go look for some poly mounts.
Re: Cummins/82 C10
Postby cmann250 » Sat May 03, 2014 7:03 pm
It was those stickers. Despite straight 4" exhaust, I catch people rolling up on me at stop lights looking for Cummins badges. They don't exist. :lol:
You gotta fly under the radar bro 8)
Re: Cummins/82 C10
Postby ellis93 » Sat May 03, 2014 7:05 pm
Nope not the stickers.....it was the noise. That crack head had followed me for awhile before trying me out :)
Re: Cummins/82 C10
Postby dazedandconfused » Sun May 04, 2014 6:37 am
I don't screw with anyone anymore on the street. After getting ran off the road by some Dick because my turd was beating his I said no more.
Re: Cummins/82 C10
Postby cmann250 » Sun May 04, 2014 6:58 am
I know I have hard time backing down from a challenge, so I go the extra mile to fly under the radar. Who would challenge a dirty old farm truck? :lol:
Re: Cummins/82 C10
Postby dazedandconfused » Sun May 04, 2014 7:42 am
You have seen mine and they still screw with me.
Re: Cummins/82 C10
Postby cmann250 » Sun May 04, 2014 7:52 am
:lol: Some one must have let the cat out of the bag.
Re: Cummins/82 C10
Postby dazedandconfused » Sun May 04, 2014 8:00 am
Ellis are upu running straight pipe or some kind of muffler?
Re: Cummins/82 C10
Postby ellis93 » Sun May 04, 2014 10:53 am
Straight pipe. Mufflers are for old people :lol:
No seriously tho I just don't think that would do any good. The motor alone makes a huge pile of noise,I think there's something up with the timing. It has to be advanced pretty far,it sounds like a 24 valve,I kid you not. Problem with that theory is it was timed with the case pin and that thinger on the pump. That should have it back stock.
Re: Cummins/82 C10
Postby dazedandconfused » Sun May 04, 2014 11:03 am
Mine is loud but I run a 4" muffler to help with drone since mine dumps at the ground in front of the axle. I think I need to pull some timing out of mine.
