Tacoclaw wrote:What am I seeing, did I'd blow out of the bottom of the tappet cover?
Tacoclaw wrote:None of us could find it because your oil isn't pitch black like ours.
I'd try a little gasket-tack on it myself, I never put anything together without it anymore. I only use it on one side of the gasket, and that's whatever side comes off with a part so I can clean it off easily when I need to.
What's up with losing 2 gallons of oil through a non-pressurized gasket leak?
dazedandconfused wrote:Are you sure your vent isn't clogged? I can't see why it would have done this myself other then crazy amounts of pressure buildup.
