Cummins/82 C10
Re: Cummins/82 C10
Postby DMan1198 » Thu Jul 24, 2014 10:14 am
Yeah a billet sigma would be a good towing pump
Re: Cummins/82 C10
Postby ellis93 » Thu Jul 24, 2014 5:29 pm
Sure,I'll take one......who's buyin? :lol:
Re: Cummins/82 C10
Postby dazedandconfused » Mon Aug 04, 2014 9:55 am
Have you got all your bugs worked out.
Re: Cummins/82 C10
Postby ellis93 » Mon Aug 04, 2014 6:05 pm
All but two,front tires still shake and I have yet to fix the side cover.....the patch is holding up fine :lol:
I'm concentrating on the ford for now,it's gotta go. My wife has driven it and wants to keep it :o I have to hurry up and get the title back so I can sell it to a guy that's buggin me for it.
Re: Cummins/82 C10
Postby dazedandconfused » Mon Aug 04, 2014 6:38 pm
Of course its the truck you don't want to keep that your wife would want to keep. :mrgreen:
Re: Cummins/82 C10
Postby PToombs » Tue Aug 05, 2014 5:21 pm
That just perfectly shows how dumb most women are! :lol:
Re: Cummins/82 C10
Postby DMan1198 » Thu Aug 07, 2014 8:15 am
I guess hurry up is right. Sure as heck don't want to keep what of those devil machines
Re: Cummins/82 C10
Postby ellis93 » Wed Sep 03, 2014 5:50 pm
Well.....I have actually worked on it again :lol:
Built a hitch for the rear that would allow me to retain the spare tire in its proper spot,sorry no pic yet.
And FYI to everyone.....hancook tires are the devil. They have been the issue the whole time. Looks like I'll be saving some nickels and dimes to buy some bfg's :?
Re: Cummins/82 C10
Postby ellis93 » Mon Sep 29, 2014 4:37 pm
The quest for power begins! 8)
Stage 1: gauges and make a pod to hold them. I'm starting on the pod now. It will house the lockup toggle and the cruise toggles.
In progress
Stage 2 will be installation of the 3k gov springs and side cover repair. I'm thinking of a billet unit,gotta check with rc about that.
Stage 3 will be addressing the trans. There's already a "basic" upgraded converter in the trans (billet cover) but it's loose. I'll be trying out the 50/50 hydrualic fluid/+4 at first. If it doesn't tighten things up enough,then 100%,after that I'll send it off to be "fixed".
Stage 4 will be adding as much fuel as the stock components will allow,run it,then if it isn't enough to hurt feelings then the honed 7x10 tips are thrown on 2nd gen bodies and installed. Probably will be a turbo rebuild in there along with that 62mm bae upgrade compressor. Idk might just try out one of those fancy things Eric (rc) offers, on the dodge and the hybrid off the dodge on here. We'll see :lol:
All of this is brought to you by a punk a$$ kid and his mommie bought duramax. Tried it and was handed my ass in my hat :lol:
Re: Cummins/82 C10
Postby PToombs » Mon Sep 29, 2014 5:36 pm
Maybe it's the pic, but are you putting in 4 inch gauges for your blind old ass? :lol:
You gotta be careful with those dirtymaxs, those things are bad with only a little done to them. Friend had an '05 that would go 10.57 in the 1/4, sled pull, and go get groceries in between. He figured it was about 600 hp, had EFI live and a bunch of other stuff done. Really nice truck, I try not to bash them too bad.
Unless it's Dudney. ;) :lol:
Re: Cummins/82 C10
Postby dazedandconfused » Mon Sep 29, 2014 5:41 pm
Unless they limp the ally its hard to outrun a duramax with our trucks. I plan to start turning mine up this spring when. I build a trans finally.
Re: Cummins/82 C10
Postby PToombs » Mon Sep 29, 2014 5:45 pm
Yeah, with my stick I don't think I'd even try to take one on. Even stock they're pretty quick.
Re: Cummins/82 C10
Postby ellis93 » Mon Sep 29, 2014 5:52 pm
dazedandconfused wrote:Unless they limp the ally its hard to outrun a duramax with our trucks. I plan to start turning mine up this spring when. I build a trans finally.
Pete,Andy.....I expected to lose....just not quite that bad. I got walked,hard :lol:
I'm sure I'll loose again,I just don't want it to happen so bad again. ;)
I figure with the low-ish weight I have,that the little basic mods I will have can serve me well in another encounter.
No Pete 2" gauges. That oak board isn't but 3" wide,the pic is close up as well :lol:
Re: Cummins/82 C10
Postby PToombs » Mon Sep 29, 2014 5:56 pm
I guess it's close! I didn't even need my bifocals for that! ;)
Re: Cummins/82 C10
Postby dazedandconfused » Mon Sep 29, 2014 6:04 pm
You have an advantage and should be able to hang with him once you start throwing fuel to that p-pump. I'd swap those nozzles and step up to a 62 or a healthy hybrid. I've seen some nice HX35 hybrids being made. Remember a crew cab short bed D-max isn't that heavy.
