Cummins/82 C10
Re: Cummins/82 C10
Postby ellis93 » Wed Nov 05, 2014 7:24 am
Still have not done anything for the pressure lose while the engine is under load (from 50psi down to 30 and 35) but the truck seems stronger. Feels better from a stop but still lacking in the upper rpm range,2400 and above.
I found an inline strainer for gas applications laying in my junk drawer of the tool box so I'll be throwing it on in place of my filter under the bed.
I also got my injector tester in yesterday.....pulled it out of the packaging and seen the guage setting on 900psi, sob. :roll:
Bad thing is I'm getting a fuel knock here lately at idle,and figur it might be injector related.
Re: Cummins/82 C10
Postby PToombs » Wed Nov 05, 2014 5:55 pm
I toldja about that tester! :lol: Seriously though, did you ever look for that thread?
I found 2 of them, 1 was yours looking for a tester, and the other was by BC when he bought his, viewtopic.php?f=4&t=9545&start=15
Re: Cummins/82 C10
Postby ellis93 » Wed Nov 05, 2014 6:46 pm
Yeah I looked Pete. I found BC's tread as well and this one looked similar in design and I figured I'd gamble. I got a hold of the seller and he's sending another gauge for it.
I did go ahead and try it out tho,it popped the loose second gen injector I had in it so the rest of the tester seems fine. It's a hell of a lot nicer to use than my contraption :lol:
Re: Cummins/82 C10
Postby PToombs » Wed Nov 05, 2014 7:16 pm
I was looking at the pics in your thread when you built it. I was chuckling about it, but if it works then WTH, right? ;)
Re: Cummins/82 C10
Postby ellis93 » Wed Nov 05, 2014 7:45 pm
It works...far. You just have to pump and pump to get it to pop the injector your testing and you won't be doing any leak down testing with it like an actual tool. But if your in a bind or have time to kill to make one then it'll do.
Re: Cummins/82 C10
Postby DMan1198 » Thu Nov 06, 2014 9:02 am
Sooo... Why no pictures of this unit? I kind of want something like that
Re: Cummins/82 C10
Postby ellis93 » Thu Nov 06, 2014 1:44 pm
Cause I posted an eBay link to it. The real peach is the frankintester,that one is great :lol:
Re: Cummins/82 C10
Postby DMan1198 » Thu Nov 06, 2014 3:34 pm
Yeah but clicking links seems like a lot of work. That's hard on the professional nap takers
Re: Cummins/82 C10
Postby ellis93 » Fri Nov 07, 2014 10:01 am
The fuel/water separator was the problem. It now holds 40lbs while I'm calling on the fuel hard. My idle fuel pressure still isn't any better tho. Looks like I'll be doing the regular thing that KTA suggested in the metal part of the return line. Anybody want to buy a tork tec overflow valve :roll:
How I deleted my fuel/water separator is I had one of these
It has a very fine screen in it that should be able to keep crap out of my supply pump but the in and out ports were tiny. I knew it would slow the flow of fuel if I left it like that. So I drilled out both ports and the holes in the cross tube inside to as large of a diameter as I could get before weakening the assembly. Didn't want it to fall apart when tightening it up.
We'll see how this does once I get the regulator rigged up. Hopefully it works out.
Re: Cummins/82 C10
Postby ellis93 » Fri Nov 07, 2014 6:41 pm
Guys!?!?
I have a supply pump off a 2002 f250 7.3.....it has almost no volume but it builds a crap ton of pressure,reckon I could use it to move fuel from the tank to the piston pump?
I have been thinking on it and I went back thru bigblues tread again and he's using a knock off Holley pump to feed his junker drag truck.
Re: Cummins/82 C10
Postby PToombs » Fri Nov 07, 2014 7:08 pm
Get 1 good pump, put 1 good pump on, run 1 good pump. See the pattern here? If the ferd pump dies can the stock pump pull thru it? Probably not, and you'll burn that one up too. Spend the money 1 time, on 1 good pump, and have 0 problems. MO, not H. ;)
Re: Cummins/82 C10
Postby DMan1198 » Fri Nov 07, 2014 7:12 pm
I'm going to agree with Pete on running one good high volume pump
Re: Cummins/82 C10
Postby Remps » Sat Nov 08, 2014 1:48 pm
I ran one of those 7.3 pumps with a ve and 5x18's. I could pull it down to 14 psi, regulated at 17. Was making 37 psi with a 54 mm h1c. The pump was inline on the factory fuel line, bypassing the diaphragm pump. I think it would have done a little better with a bigger inlet fuel line to the pump. And the ve would not pull fuel through it.
Re: Cummins/82 C10
Postby oldestof11 » Sat Nov 08, 2014 6:22 pm
A cheap and popular Powerstroke upgrade pump is the Walbro GS392 regulated down. I ran one in my old candy cane truck. It was a good upgrade.
Re: Cummins/82 C10
Postby DMan1198 » Sat Nov 08, 2014 9:09 pm
Waterman 400gph ftw. It's mechanical and small. Requires a front cover change, and 5/8" line is recommended, but it'll keep up with any fuelling I think
