Excursion 12v/nv4500
Re: Excursion 12v/nv4500
Postby PToombs » Tue Jan 05, 2016 5:51 pm
You bought a new pump for it? Oh man that sucks. Don't open it and call the seller and see if they'll take it back if unopened, maybe you will only have to pay return shipping.
Glad you found the bolt and that was it.
Goes to show you never quite know what can go wrong, look how long everybody has been trying to help fix it, and none of the common problems was it.
Postby Gots_a_sol » Tue Jan 05, 2016 6:52 pm
Yea I appreciate the help ya'll offered. I feel dumb that it ended up being a simple banjo bolt that I uhh err my mechanic put in the wrong spot :lol:
-Joe
Gots_a_sol
Postby ellis93 » Tue Jan 05, 2016 7:20 pm
Yeah that is something extra special that I'll file away in the memory bank. Glad you got it going.
Postby Gots_a_sol » Thu Jan 14, 2016 9:34 am
Since it is running again, decided to make it official :lol: (the C is chrome, not black)
Also since it has been so cold lately, I planned on putting the block heater cord back on. Only problem is the turbo oil drain tube is right up against the block and I don't have room to reattach the cord. Arrrg!
-Joe
Gots_a_sol
Postby PToombs » Thu Jan 14, 2016 5:25 pm
Not that it would be easy, but you could move the block heater and put a new soft plug in the old hole. ;)
Postby 12Vexcursion » Sun Jan 17, 2016 6:05 pm
Hey. Building a 2000 excursion now.
What did you do for the nuetral safety switch wiring and . The back up lights for the nv4500?
12Vexcursion
Postby Gots_a_sol » Sun Jan 17, 2016 6:34 pm
I just tied together the wires to make it start for now. I have the actual switch but haven't wired it yet.
The wires for that and the reverse lights go to the position switch do dad on the the trans. I might have the colors written down out in the garage, I'll look tomorrow.
-Joe
Gots_a_sol
Postby 12Vexcursion » Sun Jan 17, 2016 7:05 pm
Would be much appreciated. I won't put one on the clutch rod. Just bypass the automatic ones. Thanks man
12Vexcursion
Postby Gots_a_sol » Sun Jan 17, 2016 10:13 pm
Looking at my notes on the computer and I'm 99% sure this is correct.
Starter:
Straight circuits, no PCM or GEM involved. Jumping the DB/OG and TN/RD from the range switch will allow the starter to run at any time the key is moved to start.
Reverse lights:
Running the LB/PK and the BK/PK wires from the range switch to the reverse switch on the transmission should take care of this.
-Joe
Gots_a_sol
Postby 12Vexcursion » Mon Jan 18, 2016 12:26 am
Okay thanks
Is the reverse switch on the no just a two pin connector?
12Vexcursion
Postby Gots_a_sol » Mon Jan 18, 2016 8:37 am
Yea, simple 2 pin switch on the NV. I believe it uses a standard weatherpak connector too.
-Joe
Gots_a_sol
Postby 12Vexcursion » Wed Jan 27, 2016 2:50 am
Hey
Got another question
Dropped and drained my tank yesterday and installed my sump.
Wanting to kill power to the stock pump but retain the function and power of the fuel level sending unit.
Did you do this? Have the power wire color I need to kill? Thanks again
12Vexcursion
Postby Gots_a_sol » Wed Jan 27, 2016 6:08 pm
I believe I pulled either a relay or fuse out of the underhood fuse block
-Joe
Gots_a_sol
Postby 12Vexcursion » Wed Jan 27, 2016 7:51 pm
Awesome thanks
12Vexcursion
Postby Dieselwrencher » Thu Jan 28, 2016 7:56 pm
Very nice excursion! When I built my wife's I had the same issues getting it running. I didn't have the correct return banjo bolt. What a pain that was. Haha
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
