Studebaker with a 5.9 cummins
Postby Luckydugan » Sun Jun 19, 2011 7:22 pm
:grin:
1993 Dodge W250 16cm Turbine Housing, Fuel pin, Spring, 60 HP Injectors, 3 1/2 " Exhaust, BD Performance Torque Convertor, ISSPRO Boost,Pyro,Tach,Tran Temp gauges. M/T Challenger Rims. 1993 Lance 900 ( 11'3').
Luckydugan
Re: Studebaker with a 5.9 cummins
Postby dazedandconfused » Mon Jun 20, 2011 4:15 am
pic doesn't show up for me.
Postby ellis93 » Mon Jun 20, 2011 6:21 am
I see it. Got any more?
Postby 1arock » Thu Jun 23, 2011 5:17 pm
I see it too (big picture) is it yours? Details?
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
