crewcab build progress
Postby simplysmn » Tue May 22, 2012 8:57 pm
http://i1090.photobucket.com/albums/i37 ... 11_540.jpg this is my starting platform
http://i978.photobucket.com/albums/ae26 ... 1_1395.jpg
waiting on frontend conversion
http://i978.photobucket.com/albums/ae26 ... 45_721.jpg work done over last Sat
this is a picture of my last truck I built 2 times over
had it for over 20 yr's went through 3 gas motor's before swapping to Diesel then we rolled it and then rebuilt it and then Sold it :) but got the bug for a 12 Valve so I'm building another as we speak
:D
here is a picture of it upside down and yes we both walked away from it with just scratches and bruises
http://i978.photobucket.com/albums/ae26 ... MG0295.jpg
simplysmn
Re: crewcab build progress
Postby BobS » Wed May 23, 2012 5:19 am
Was your crew fitted with a suspension and/or body lift? I plan on keeping my crew project setting no higher than the stock height of the 92 dodge donor truck to try and prevent this.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby CumminsPower59 » Wed May 23, 2012 5:31 am
Poor truck, glad you got out without a ride in a meat wagon.
Yeah, that thing looks like it had 4-6" of lift under it.
Postby simplysmn » Wed May 23, 2012 6:48 am
well there was Nothing that was going to stop this we hit Solid Ice at 15-20 mph and didn't know it till last sec we were along for the ride yes it had 5 in lift n 3 in body lift with 37's on it at the time had already driven thourgh 90 miles of bad snow and Ice and we were less then 3 miles from clear road when we slid into bankment and flipped over I will post more if you want to see it that same truck was running again 2 n 1/2 month's later :) the side you see was MY side and can you picture a 7 ft tall guy crawling out that window scared to death because my wife was on other side trapped by seat belt up side down
simplysmn
Postby simplysmn » Wed May 23, 2012 9:19 am
http://i978.photobucket.com/albums/ae26 ... htside.jpg
this is the box that saved our lives it was 4x4x18 inches high and had a 200 lb helicopter rotor in it when I loaded the box and everything else at the Base out side of reno NV that Morning I had put a cargo net over the bed well when we flipped the net held enough to let the box slide down and stop under the edge of the bed so that help up the rest of the truck
http://i978.photobucket.com/albums/ae26 ... tfront.jpg
this was my wifes side Thank goodness she's Short because the cab on her side was squished
had some interesting times the last few yr's but thing's can Only get better Right ???????
The problem was this Road should have been Closed due to road condition's but because Nevada has Casino's and the area of Ca I believe it's called Jackson Ca has a Indian casino they keep the road open at all cost for the time this happened and sat (3) day's when the tow truck showed up to bring my truck back home there were 2 fatality accident's in the same area we rolled and they never closed the road . Good thing was we weren't hurt Bad because the Ambulance never showed up heck it took CHP 20 min's to get there
simplysmn
Postby PToombs » Wed May 23, 2012 5:33 pm
Wow. I never saw those pics on TDR, I musta missed them. Glad you made it out of that ok.
Was the rotor ok, or did it have to be scrapped?
Postby oldestof11 » Wed May 23, 2012 6:51 pm
Wow...
Good progress bud!
Postby CAJUN 93 » Wed May 23, 2012 7:08 pm
i've been playing around with the idea of adding a small roll cage-bar in the crew when i build it. after seeing how your roof collapsed i'm thinking much more. no one ever plans to put one on the roof, it just happens. good to know no one was hurt. could have been much worse.
daryl.
CAJUN 93
Postby simplysmn » Wed May 23, 2012 8:24 pm
well what did the roof in is we went up the enbankment and then flipped at a angle it was sure a Wild ride and to boot motor was still running upside down till I hit switch really quick
simplysmn
Postby simplysmn » Wed May 23, 2012 8:26 pm
PToombs wrote:Wow. I never saw those pics on TDR, I musta missed them. Glad you made it out of that ok.
the Rotor never came out of the box and it was fine I never even told the company about it it didn't hurt it so why stress them out :D
simplysmn
Postby PToombs » Thu May 24, 2012 5:30 pm
Postby m880cummins » Mon Jun 04, 2012 7:14 pm
Probably realized those Goodyear MT hummer tires aren't the best on ice when you hit the pedal. Looked like it was a helluva truck tho.
Good luck on the build!
Charlie
SUNY Maritime Class of 2017!
m880cummins
Postby simplysmn » Mon Jun 04, 2012 7:28 pm
the wierd part was that was 3 miles from Clear road after driving over 90 some miles in Snow n ice we hit that corner and it was done .As for that truck it was rebody'd in 2 month's and sold I never turned it into insurance company because I had basic insurance not full . But the new build will have bit's and pieces of the old truck not sure if you can see it but I had a 440 six pack scoop on it and it had a Minor crack in it well it's going on this truck
simplysmn
Postby simplysmn » Mon Jun 04, 2012 7:32 pm
the truck then had roughly 6 in lift front n rear plus 3 in body lift after I rebuilt it I went to 8 in front spring's dual shock's and 39's and with body lift it was around 11 inches
simplysmn
Postby BobS » Tue Jun 05, 2012 4:18 am
simplysmn wrote:the truck then had roughly 6 in lift front n rear plus 3 in body lift after I rebuilt it I went to 8 in front spring's dual shock's and 39's and with body lift it was around 11 inches
If I'm reading this right I get 15" above stock height. The stock 16" or 16.5's are on average around 31" tall. Going to 39's the difference in tire height is 39-31 which is 8, divided by 2 equals 4". Tire height difference [4"] + front springs lift [8"] + body lift [3"] equals 15 inches above the original 4WD factory height. In order to maintain a similar factory center of gravity you would need to widen the tread width a width equal to or greater than the total increased amount of lift. Didn't Dodge got rid of its old treadwidth on full size factory trucks starting in the mid 90's? Our trucks have the same treadwidth going way back into the 1960's. This early somewhat narrower treadwidth in combination with a lifted Cummins Diesel engine drivetrain's weight work against anybody who elevates the heavier drivetrain.
BobS
89 D350 Stock
BobS
