cummins m715
cummins m715
Postby fabricator » Thu May 24, 2012 7:41 pm
building a m715 with a cummins swap. heres what it looked like when i got it.
dropping the motor in
fabricator
Re: cummins m715
Postby oldestof11 » Thu May 24, 2012 7:57 pm
Are those Pitbull 37's? Or Treadwrights Guard Dogs?
Looking good!
Re: cummins m715
Postby fabricator » Thu May 24, 2012 8:13 pm
goodyear mtr 40 inch
fabricator
Re: cummins m715
Postby CumminsPower59 » Fri May 25, 2012 7:22 am
That thing is pretty bad ass! Keep us updated on the build. I have always liked those old Kaisers :mrgreen:
Re: cummins m715
Postby Tacoclaw » Fri May 25, 2012 10:02 am
Looks awesome! What color did you paint that engine? That's a really nice color.
Re: cummins m715
Postby PToombs » Fri May 25, 2012 5:53 pm
I think you skipped a few steps between pics 3 and 4. :lol:
Re: cummins m715
Postby RumbleFish » Fri May 25, 2012 7:11 pm
I like your roof!
Re: cummins m715
Postby fabricator » Sat May 26, 2012 5:27 am
the engine is painted an industrial machine grey. these are older pics, but i dont think i missed to much between the 3rd and 4th. except the motor mounts. i just used the 1st gen crossmember. it fit nicely between the m715 frame rails.
fabricator
Re: cummins m715
Postby fabricator » Sat May 26, 2012 5:29 am
have had lots of eemarks on the roof. haha. i will see about some new pics this weekend
fabricator
Re: cummins m715
Postby CE_TX » Sat May 26, 2012 2:07 pm
Nice build!!
I've got a 68 M715 awaiting the same fate when I get my crew cab done.
1985 Dodge W350 Crew Cab with 1992 Cummins drivetrain---undergoing frame off restoration.
CE_TX
Re: cummins m715
Postby PToombs » Sat May 26, 2012 6:24 pm
I meant it went from red and dead to clean and green. :lol:
Re: cummins m715
Postby fabricator » Sun May 27, 2012 8:01 am
swapping on a newer variable geometry turbo that is now setup to run off boost pressure. also because i plan on running a intercooler.
also a pic of the start of the exhaust
fabricator
Re: cummins m715
Postby bmoeller » Sun May 27, 2012 8:25 am
Someone pull the silencer ring out of it once? Looks dinged..............
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: cummins m715
Postby fabricator » Sun May 27, 2012 12:47 pm
could have been out before. turbo was a freebie so who knows. m715 doesn't have a heater so i might hook the heater lines from the engine to the turbo.
fabricator
Re: cummins m715
Postby fabricator » Sun May 27, 2012 1:28 pm
going to be running a friends loaner ve pump until i can find parts to fix the one that came with my engine. i need a stock 12mm ve pump head
fabricator
