Dirtfloorfab's DEM suburban/pickup conversion and 12v swap
Postby bighroder » Sat Sep 01, 2012 4:47 am
Well I had an 86 suburban the roller was from arizona so it was real clean I bought it for 1200 an
d it looked like this
After a bunch of time working on it and some parts off the parts truck the back half looks like
from the front
I'm also doing a tilt front end (I'm a diesel mechanic, just a personal touch) I'm also lifting the nose of the hood, (think 01 and 02 chevy duramax hood) and with any kind of luck I'll have my ve pump 12v at the house by tuesday
The truck has 14 bolt, dana 60 front not installed yet, getting 205 nv4500 I'm sure I'll have questions about tuning the ve I've only worked with p pump and newer so itll take a min to learn
86 suburban/pickup conversion project "Dont Even Matter"
Dana 60, 14bff, 12v ve, nv4500, np205
http://1stgen.org/viewtopic.php?f=32&t=13252
bighroder
Re: Dirtfloorfab's DEM suburban/pickup conversion and 12v swap
Postby dazedandconfused » Sat Sep 01, 2012 5:23 am
I like it, old school Avalanche. :)
Postby oldestof11 » Sat Sep 01, 2012 7:00 am
Love it!
Postby bighroder » Sat Sep 01, 2012 8:40 am
Thanks for the compliment guys I'm gunna be running military bias 36's(whats on the rear axle) I wanted 373 but it has 410s right now il see how it works then regear as necessary
Heres some big questions I have, my donor motor is an 89 I plan to swap injectors tune the pump maybe a small set of compounds water to air intercooler and water methanol injection, are there any other things I should be looking at? Am I crazy to expect 400 horse from a setup like this? For that type of hp would it still be reliable? I really dont want to go 14mm pump and I dont want to lose all my mileage.
Also whats a good injector that would be efficient with my power goals? I was looking at scheid s +40hp set but they are a little pricey I just dont want to throw pods on and lose all my mileage
bighroder
Postby oldestof11 » Sat Sep 01, 2012 9:06 am
Pods are just a tiny bit bigger than your current injectors if they are stock. Your stock injectors are the biggest that ever came in a 12v. ;)
5x14-5x16s is a good injector. Places like Cummins Performance Parts (Hamilton Cams is using them and Weston has said he has sent them injectors after the SDX fiasco), DDP just to name a couple.
With the right mods, 400hp is very possible.
Postby bighroder » Sat Sep 01, 2012 9:26 am
Do you think 400 is achievable with stock injectors tho? I knew they were big to begin with but I didnt figure stockers would get me there.
bighroder
Postby cmann250 » Sat Sep 01, 2012 9:34 am
I'd doubt you can hit 400 reliabily with stock injectors. 3-350, maybe
Postby bighroder » Sat Sep 01, 2012 8:34 pm
thats Kinda what I figured but I might run stockers and build to it as I go
No more dana 44 making way for the 60
bighroder
Postby dazedandconfused » Sun Sep 02, 2012 6:18 am
Somebody on here is running honed stoker's and making over 400 if i remember. I thing its the guy with the ram charger. His user name starts with Rc i believe
Postby bighroder » Sun Sep 02, 2012 7:17 pm
Dana 60 converted to srw painted and put in just wish my roller tires would hold air
bighroder
Postby PToombs » Mon Sep 03, 2012 4:59 pm
Are they leaking around the beads? If so, break them down, coat them with vaseline, and reinflate. Done deal.
I had to do that on an Astrovan the wife had and they never leaked again.
Postby bighroder » Mon Sep 03, 2012 6:09 pm
PToombs wrote:Are they leaking around the beads? If so, break them down, coat them with vaseline, and reinflate. Done deal.
No I don't think it's on the bead they ate just cheap roller tires I bought for 50 bucks they are 36's so I can't expect much they are pretty dry rotted I just wanted mock up tires
bighroder
Postby ellis93 » Mon Sep 03, 2012 6:33 pm
Have alot of that around do ya
Postby PToombs » Tue Sep 04, 2012 5:07 pm
Nope, the cat is real partial to it for some reason. :mrgreen:
Postby dazedandconfused » Tue Sep 04, 2012 5:18 pm
PToombs wrote:Nope, the cat is real partial to it for some reason. :mrgreen:
So Jon will put a bottle up his rear for a certain price and you put vaseline up yours for the cat? :shock: :lol:
