The Blue Goose
The Blue Goose
Postby 88Centurion » Tue Oct 23, 2012 5:36 pm
Ok guys here she is. Got alot of ideas going through my head right now but ill put some of it out there and get your opinions and suggestions. 92 W150 Has 318 and a 518 with a d60 rear not sure what gear yet. The trans wont shift past second and the motor smokes a lil so dont know of ill get any thing back out of that or not. Bought a engine and 727 out of a 89. Engine has aronud 300000 on it but it runs great and came with the complete wiring harness inside and out. Pump rebuilt not to long ago and had a head gasket put on at some point. Trans was supposed to have only 10000 miles on it. Still trying to figure out exactly what to do. Want to have a dd that gets good fuel mileage but still have plenty of power to play.
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Tue Oct 23, 2012 5:45 pm
If your going yo keep the 727 you are going to need 3.00 or higher to run highway speeds. You sure its a 60 under there?
Re: The Blue Goose
Postby 88Centurion » Tue Oct 23, 2012 6:02 pm
Yeah its a 60 some one some where along the way put it in. Thought about a 47rh but really want it to shift on its own and not have to run the over drive and converter lock on switches. Dont know how difficult that would be. Will the 518 behind that gasser bolt to a cummins or is it a diff bell housing. I'd be satisfied with that i think if it would work.
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Tue Oct 23, 2012 6:10 pm
No its a different bellhousing. I wonder if that 518 has lockup though. If so i believe you may be able to convert a diesel 518 into lockup with some other changes. Someone smarter then me will have to answer though. You can put pressure switches on the 47rh to make it shift on its own though.
Re: The Blue Goose
Postby 88Centurion » Tue Oct 23, 2012 6:26 pm
I figured it was different and i'm not sure on that drove it home in second. I think i may be able to put my hands on a 47rh so that may be the best way to go instead of trying to come back and do it later.
88Centurion
Re: The Blue Goose
Postby kansascrewcab76 » Wed Oct 24, 2012 9:40 pm
I will be looking to sell the 518 from my 91.5 2wd donor truck in the next week or so. If you interested it has 40K on a rebuild, run, shifts excellent, pink fluid and all.
If your interested pm me
1976 Dodge Crew 440-->soon to be a Cummins
1993 D250 cummins Papa truck 90K
kansascrewcab76
Re: The Blue Goose
Postby 88Centurion » Thu Oct 25, 2012 4:52 pm
I may be interested but cant send pms yet says i havent posted enough. But im gonna do some looking and researching and try to decide beween the 518 and the 47rh. Maybe by the time you get ready to sell it i can pm and we'll see how things work out.
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Thu Oct 25, 2012 5:03 pm
If you got a chance to get a 47rh do it.
Re: The Blue Goose
Postby 88Centurion » Thu Oct 25, 2012 6:07 pm
Thats kinda what im thinking. I think i know where there is a wrecked 94 that i might could buy for cheap. Trans is shot and is missing rear end but would be a good start i think.
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Thu Oct 25, 2012 6:12 pm
Yeah i have a 518 that will go for a 47rh or full manual 47Re
Re: The Blue Goose
Postby CumminsPower59 » Fri Oct 26, 2012 5:28 am
What's the story with the FJ40 next to the Dodge? I love those old Land Cruisers :mrgreen:
Re: The Blue Goose
Postby 88Centurion » Fri Oct 26, 2012 4:40 pm
Picked that up from a hunter. Had carb rebuilt new plugs new water pump and she runs like a champ.. Gonna try to get more than one of the brakes working then see what i can get out of it. One front brake and wore out shocks makes for quite the interesting ride.
88Centurion
Re: The Blue Goose
Postby 88Centurion » Sun Nov 04, 2012 7:28 am
Could you run a 47re without it being full manual and not alot of head ache trying to get it to work right. Think i found a good deal on a whole truck with one in it.
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Sun Nov 04, 2012 7:32 am
The re is all electric. If you ran that engine and complete wiring harness it wouldn't be that bad.
Re: The Blue Goose
Postby 88Centurion » Sun Nov 04, 2012 12:31 pm
I really want to stay with the ve so guess ill just have to try to find a rh. Seems like it would be easier.
88Centurion
