89 RC 6BT swap.
89 RC 6BT swap.
Postby derka540 » Mon Dec 03, 2012 6:00 am
Hello folks, new here, but have been reading many threads for research.
I have read quite a bit on this, and I'm actively searching for a donor truck. Im just looking for some advice from those who have done the swap into a RC or w/d 150 trucks. I plan on obtaining an 89-93 CTD 3/4-1 tonne at a reasonable price, and swapping the motors with my ramcharger.
Now in most swaps i have read, they swap the running gear (obvious reasons) but if i were to leave the running gear is it is, (d44 front d60 rear) and add an overload spring to the front leafs can i get away with this?
My rig: 1989 RC, 360 4x4, 727tf 4 inch lift/33"
derka540
smoke screw?
Re: 89 RC 6BT swap.
Postby derka540 » Mon Dec 03, 2012 6:03 am
Also to confirm, bolting the 6bt to the 727tf, is direct bolt, right? somewhere i read something about a bell-housing has to be changed.
derka540
smoke screw?
Re: 89 RC 6BT swap.
Postby Tacoclaw » Mon Dec 03, 2012 10:05 am
The diesel trans has a completely different bellhousing setup on it and AFAIK. They're not interchangeable, so you'll have to use the trans that came behind a diesel.
I have no experience with using the 44 under a Cummins but I wouldn't do it. I'd assume it would chew up balljoints pretty bad.
Re: 89 RC 6BT swap.
Postby dazedandconfused » Mon Dec 03, 2012 10:13 am
If your just going to cruise it on the street and not beat on it with near stock power you will be ok. It will eat balljoints faster but will live. Now if you take it off road i would swap a 60 in the front at least.
Re: 89 RC 6BT swap.
Postby derka540 » Mon Dec 03, 2012 5:35 pm
Thanks for the input guys. I found a donor truck for 1800, im going to look at it tonight, but has a bad trans...Can you confirm for sure they wont bolt? can i swap the bell-housing?
derka540
smoke screw?
Re: 89 RC 6BT swap.
Postby SuperiorRam » Mon Dec 03, 2012 5:47 pm
No v8 trans will bolt up
1800 is a good price that's what I paid for my first donor and the trans and rear end were fried
Good luck
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
