Adapting my a/c
Adapting my a/c
Postby vefummins » Mon Feb 18, 2013 10:21 pm
Can anyone help me adapting my Ford a/c lines to the Dodge a/c compressor
87 f250 with 92 I/c cummins.to much goin on under the hood
vefummins
Re: Adapting my a/c
Postby ellis93 » Tue Feb 19, 2013 2:38 am
What would you like to know?......There are part stores,places that specialize in auto a/c,that can use the hose manifold off your compressor and the dryer/condenser hookups from a set of ford lines to build you a set of custom lines. As far as making the compressor generate the pressures need for the ford orifice tube system,that shouldn't be an issue as it takes less pressure to work it than the expansion valve system that dodge has on these old trucks.
Re: Adapting my a/c
Postby vefummins » Wed Feb 20, 2013 8:29 pm
OK so its really not do it yourself kind of thing
vefummins
Re: Adapting my a/c
Postby ellis93 » Thu Feb 21, 2013 4:43 am
vefummins wrote:OK so its really not do it yourself kind of thing
Well if you had the bulk hose and the ends you could put it together but you'd end up using hose clamps to hold it all together,which would look bad.
Back in the days of old cars with add on systems and the gas used was R12,that's how the line were held together.
Re: Adapting my a/c
Postby vefummins » Thu Feb 21, 2013 7:57 pm
Yeah I don't want it to look bad.just another thing I have to save up for
vefummins
