Cummins/82 C10
Re: Cummins/82 C10
Postby PToombs » Tue Mar 15, 2016 3:50 pm
Dude, it was only 1400, why did you let out of it? I used to hit 1600 on a regular basis. :mrgreen:
Re: Cummins/82 C10
Postby DMan1198 » Tue Mar 15, 2016 4:15 pm
It looked like it was 1500 to me. I used to hit 1900+ on a regular basis with my 6.7 (I have pictures of the marshmallowed turbine wheel to prove it too), but then I got a real turbo, and it's never gotten anywhere near that hot again.
Re: Cummins/82 C10
Postby ellis93 » Tue Mar 15, 2016 5:21 pm
PToombs wrote:Dude, it was only 1400, why did you let out of it? I used to hit 1600 on a regular basis. :mrgreen:
Yeah.....silly me,on my second engine and all! :lol:
I'm going to Dick around with my timing some and see what that does for me. It's definitely not to much fuel,or air leaks. I just pressured the system up and sprayed purple power everywhere. No bubbles to be seen but then again nothing is saying that the 328k turbo is the best either. I'll Dick with the timing tomorrow.
Re: Cummins/82 C10
Postby spencerdiesel » Wed Mar 16, 2016 11:14 am
What was that in mph terms? And what'd the last pyro used to read?
H1C/18
Muffler delete
spencerdiesel
Re: Cummins/82 C10
Postby dazedandconfused » Wed Mar 16, 2016 11:20 am
On a different subject how does your trans shift using the pressure solenoids? Which ones are you using?
Re: Cummins/82 C10
Postby ellis93 » Wed Mar 16, 2016 4:23 pm
dazedandconfused wrote:On a different subject how does your trans shift using the pressure solenoids? Which ones are you using?
Andy I wound up using some adjustable units from eBay. The PATC units will work for a gasser......not so much for a diesel unit. Pre set pressure sensors suck for what you want to do.
I'm only using one for the o/d,I deleted the lockup sensor because I found it more beneficial to use a toggle.....lock it in when I want,in the gear I want.
If you can't find one I can post a pic of the box and can send one to you.
Timing was my issue on the Chevy. I installed the spacer and now 1300* is as high as it gets. I'll be bumping the base timing a fuzz as well.
Lots more power.....smoother too.
Re: Cummins/82 C10
Postby ellis93 » Wed Mar 16, 2016 4:24 pm
spencerdiesel wrote:What was that in mph terms? And what'd the last pyro used to read?
I let off at 100mph,1100*. Probably why that p pump motor died earlier. Some of it anyhow
Re: Cummins/82 C10
Postby spencerdiesel » Thu Mar 17, 2016 7:04 am
Previous motor melted? How many turns on the screw you got for it to run that well?
H1C/18
Muffler delete
spencerdiesel
Re: Cummins/82 C10
Postby ellis93 » Thu Mar 17, 2016 4:31 pm
spencerdiesel wrote:Previous motor melted? How many turns on the screw you got for it to run that well?
I bottomed the fuel screw and backed it off two turns.
The other motor started rattling and knocking at high rpm.....3K+. The trust bearings are known to be bad in it from testing the crank end play,never have opened it up to check out what else is bad.
Re: Cummins/82 C10
Postby ellis93 » Sun Mar 27, 2016 5:49 pm
Almost lost this truck today......pucker factor got really high! Left church,headed home......freakin water pocket I didn't see sucked the ass of the truck right off the road,pulling it off in the ditch with me spinning the steering wheel like a mad man to straighten it back out. Wasn't going all that fast so it wasn't really difficult to correct......it was mostly the unexpected,sudden movement :lol:
It's been running really strong with the timing spacer. As soon as I get the dodge ship shape again,we'll see what a little more timing will do,and how much of a monster the tips make of it.
Re: Cummins/82 C10
Postby PToombs » Sun Mar 27, 2016 5:58 pm
Good thing you were coming from church! ;)
Re: Cummins/82 C10
Postby ellis93 » Tue Oct 25, 2016 6:14 pm
Installed the injector tips.......good god the smoke and haze is BAD! Got to bump the timing and tune the afc.
Re: Cummins/82 C10
Postby dazedandconfused » Wed Oct 26, 2016 2:55 am
Does it feel any stronger?
Re: Cummins/82 C10
Postby ellis93 » Wed Oct 26, 2016 3:30 am
Yeah! It's just dirty.
Re: Cummins/82 C10
Postby Remps » Wed Oct 26, 2016 4:47 am
Is injector depth/washer thickness a tuning option on a 24v? What size are the factory washers?
