Jon's build thread
Re: Jon's build thread
Postby oldestof11 » Sat Jun 13, 2015 5:34 pm
Ground stock pin, timing. I have the starwheel pretty far up too. Then power screw turned in and high throttle limit taken out.
370's
HE351
HD Lift pump
Postby oldestof11 » Sat Jun 13, 2015 6:32 pm
Postby PToombs » Sat Jun 13, 2015 6:43 pm
New Farmtruck? 8)
Postby oldestof11 » Sat Jun 13, 2015 6:58 pm
Only if I p-pump it...
Not going to happen. :lol:
Postby oldestof11 » Sun Jun 14, 2015 8:08 am
Some of my GoPro's. Skip to 2 minutes in for the action.
The CR right before me that you can hear is my buddy Schrowang's truck
https://www.youtube.com/watch?v=J6r-K4Zcxms
https://www.youtube.com/watch?v=6vzorc76yLE
Postby oldestof11 » Wed Jul 15, 2015 7:07 pm
Next step in going lower:
Postby DMan1198 » Thu Jul 16, 2015 8:36 am
If I were you putting it together I'd antisieze everything. The amount of broken bolts, and seized fasteners I've been dealing with lately has been ridiculous
Postby oldestof11 » Sat Jul 18, 2015 8:30 am
That has been SOP since working on my truck.
Postby oldestof11 » Fri Aug 07, 2015 4:51 pm
Bought this Tuesday, received on Friday. Now to find a day to weld it in.
Postby oldestof11 » Mon Sep 07, 2015 6:26 pm
Wired up the solenoid on the HE351. I hocked the bracket for the HX52 wastegate actuator I had. I then plugged it into the hose on the electric solenoid. So with it off it topped out at 28 psi. Now it hits 38psi. Mid levl throttle response is greatly improved. Improved enough that I can bark the tires punching it in 3rd at 30mph.
This upcoming weekend I plan on having a few things to do. Front crank seal, upper and lower ball joints, and hopefully a rear bench seat for the kiddos
Postby oldestof11 » Thu Sep 10, 2015 6:40 pm
No pics to show but if you have ever owned a 1st Gen extended cab (club cab), you know the frustration with trying to take people with you beyond the front seats. The jump seats in the back leave a LOT to be desired.
So I did some junkyard diving this afternoon. I picked up a folding bench seat from a 96 F150. If you want the front brackets, there are 4. However, the 5 trucks I saw, they were ALL rusted and rounded off quickly. So I pulled the 2 13mm nuts at the top of the bracket and bent them out of the way. Then I pulled the brackets for the back rest by removing the 4 14mm nuts. I wanted these as the drivers side had a beefy spring to keep it pulled up. Once it goes over center, it pulls it flat.
I am working on installing it this weekend. I am reusing the stock Dodge jump seat belts. Partly to keep it the same and partly because I didn't have the big Torx wrench needed to remove seat belts.
