84 d150 manual cab-bed lwb swap to 91 cummins manual lwb????
Postby Black shadows » Sun Apr 21, 2013 8:23 pm
Hey guys! New here my name is josh. I have a 84 dodge d150 4 speed manual 2wd lwb that I want to put the cab and bed on a 91 w250 5speed manual 4wd lwb chassis... Things gunna line up pretty good???
Black shadows
Re: 84 d150 manual cab-bed lwb swap to 91 cummins manual lwb????
Postby CumminsPower59 » Mon Apr 22, 2013 5:31 am
It's almost a bolt on affair. You'll have to make the elongated hole for the transfer case shifter, and depending on what transmission is in the 91, you may have to move the transmission shifter hole around too. Now, from what I have heard, pre-85's used mechanical clutch linkages, so you may have to make some firewall modifications, so you can mount the clutch hydraulics for the 91. Besides a few small things, it's bolt on and go :thumright:
Postby RumbleFish » Mon Apr 22, 2013 6:10 am
If the 84 the a-833 trans the shifter hole won't be close at all. You'll need some firewall mods as mentioned above. At least you won't have to replace the whole trans tunnel since you already have the big one.
Postby Black shadows » Mon Apr 22, 2013 6:54 am
Thanks guys! That's just what I was wanting to hear!!!
Black shadows
