Mechanical speedo to electric????
Postby Black shadows » Wed Apr 24, 2013 8:23 pm
So I have a 91 w250 4x4 5 speed manual chassis and a 84 d150 cab/bed I'm puting on the 91 chassis. 84 cab is mechanical and 91 chassis is electric.... What can I do??? I don't want to use the 91 gauge cluster cuz it doesn't look like the 84
Black shadows
Re: Mechanical speedo to electric????
Postby BILTIT » Wed Apr 24, 2013 8:48 pm
The electric sender just bolts onto the mechanical drive gear in the t-case. Get a speedo cable that will reach and you should be fine. You may need to change the speedo gears in the t-case though.
Derek B.
BILTIT
Postby rockbuggy4x4 » Sat Apr 27, 2013 1:00 pm
When did they switch from mechanical to electric?
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Postby CumminsPower59 » Sat Apr 27, 2013 1:12 pm
IIRC, 1990 model year...?
Postby Knoberman » Sun Apr 28, 2013 9:42 am
Get a eccentric out of an old one put in the newer one.
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
Postby Tacoclaw » Sun Apr 28, 2013 9:49 am
Is this eccentric located in the gauge or down on the transfer? I've been putting some thought into this as well since I'm doing the same thing, only the opposite. electric sender to mechanical gauge.
I'm hoping the 3.07 reducer is separate from the electronic part. =/
Postby Knoberman » Sun Apr 28, 2013 10:00 am
Goes in the case, sensor comes out eccentric goes in, there is a mark on the case you match to the gear your using.
Knoberman
