What is making my 89 D150 lean
Postby bigpapad150 » Thu May 30, 2013 4:15 am
What is making my truck lean towards the driver side front tire ???
Everything looks ok underneath.
Little help...
Thanks
BP
bigpapad150
Re: What is making my 89 D150 lean
Postby ellis93 » Thu May 30, 2013 4:51 am
Pimp stance! :lol:
More than likely a mushy coil spring,all two wheel dodges do it that I've seen
Postby RCCUMMINS89 » Thu May 30, 2013 8:10 am
? every dodge 4x4 and 2x4 I've ever had/seen eventually leans on the driver's front side??? apparently the battery is too much, LOL
Postby rockbuggy4x4 » Thu May 30, 2013 10:46 am
Yup. I was gonna say the big @$$ battery too. :lol:
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Postby PToombs » Thu May 30, 2013 5:53 pm
It's actually a combination of the fuel tank and the driver. Dodge made a shim to go under the coil spring to help level the truck.
Postby CumminsPower59 » Thu May 30, 2013 6:01 pm
I bought a 83 W150 a few years back to do a 4bt conversion, bought it from the family of the original owner. Apparently he was a BIG man, had one heck of a lean to the drivers side. Seat covering was nice, but the foam was smashed, the springs were sagged on the drivers side about 1/2", even the cab mount bushings were destroyed...I sold it to fund other things :|
Postby Arnold Layne » Sun Jun 09, 2013 11:29 am
I've got a '92 150 that sagged on the driver's side real bad, previous owner was about 125lbs. and babied it bad. Had about 90K when I got it, real nice truck, I punished it into submission in about another 15K, it's in my private salvage facility now. On a related note, I'm going to change out the front springs on the '90 D350, the driver's side coil is sqwonked pretty bad, it rides about one and one-half inch lower than the passenger side. I've got new brake pads, springs, rubber bisquits and wheel seals. Is there anything else I should have on hand for this operation?
Arnold Layne
