BILTIT wrote:
Strange how a front d44 (3/4t) solid axle cant stand up to a 6BT swap but even lighter stuff does in a 2wd?
SuperiorRam wrote:First off let me say That thing is beautiful!
Second did you do the front end drop? Because I'd love to know what was done exactly for parts year and model, thanks
Third you could cut up a 3/4 Dana 60 and your 8 3/4 and builds half ton Dana rear and sleep comfortable, that's all I did I used c body 8 3/4 ends and axles on the Dana tubes and wal-la
BobS wrote:You will need the double dropped DIESEL center link + all of the associated tie rod ends and a taper reamer to install it. Otherwise you have to mount the engine higher in the frame which isn't good, or the center link rubs the oil pan.
I think I'll just label this as "D150 center link" instead of retyping it umpteen more times........
