1/2T Conversion - Front Suspension Question
Re: 1/2T Conversion - Front Suspension Question
Postby dazedandconfused » Tue Jun 18, 2013 1:18 pm
Weigh your truck the way it sits for us. SuperioRam what does yours weigh as it sits? Mine is right at 4200 with the steel wheels and big tires I have on it. My draglites weigh a third of what these wheels do.
Postby dazedandconfused » Tue Jun 18, 2013 1:26 pm
nitrofumes wrote:Thanks for the replies everyone!
Currently the truck has been lowered using ¾ ton van lower control arms with factory D150 springs. The rear however has been lowered by flipping the rear end on top of the spring. I'm running 235/75/15's on the front and 285/75/15's on the rear. The truck currently has an 8-3/4 with 3.23 gears and I feel comfortable that it will live behind the Cummins - provided I don't get the itch to bolt on slicks and see what it would run at the drag strip... Additionally I will be replacing the 727 with an A518 along with a good converter.
The truck will never be used to haul anything serious at all. The most action it would probably see is toting around a small trailer with a lawn mower on it.
The reasoning behind the swap is first and foremost I like driving my truck, secondly fuel economy, and last power. With the basic pump mods/timing advance the truck will make more power than I would ever need and get reasonable fuel mileage as well, 22-24 mpg I'm estimating. I know my modded '92 CC 4x4 D250 gets 18-20 mpg with a stock A518. So the combination of reduced weight and taller gearing will potentially get me 22-24 mpg? That's the goal anyway.
Thanks for all advice!
Just for comparison I run a 9" with a 3.25 gear and a 518 and 31" tire. I have hit 22 mpg but my trans is loose and I'm blowing threw the convertor now. I would look for a 47rh or 47re and run a manual VB in the re. You wouldn't need the pcm and could run of and lockup off switches. About 70mph I'm blowing threw my trans and hitting governor.
Postby Knoberman » Sun Jun 23, 2013 6:56 pm
Call dpc, get a convertor for that thing, you won't regret it.
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
Postby FIRST GEN. JAKE » Wed Feb 19, 2014 10:39 pm
I was planning on doing 1/2 ton sb swap but never could fine a clean one. I ended up buy a 89 srw d350 12v. I'm going to cut it down put a sb on it and lower.
FIRST GEN. JAKE
