'85 on steroids
'85 on steroids
Postby rockbuggy4x4 » Mon Sep 30, 2013 9:56 am
This is a little late but I picked up an '85 Crew cab a few weeks ago. Here's a link to the photobucket album ( http://s1287.photobucket.com/user/Jimmy ... Crew%20Cab ). I'll also post pics here too. Hope ya'll got some popcorn ready. 8)
'85 cab w/ '89 Cummins
'85 D350
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Re: '85 on steroids
Postby simplysmn » Mon Oct 07, 2013 9:38 pm
You Deffently have your work cut out for you bud . keep us up todate with Pic's and Info .
simplysmn
Re: '85 on steroids
Postby rockbuggy4x4 » Tue Oct 08, 2013 7:19 am
yup. will do. I got get my suburban running before I tear into these trucks.
Jimmy
rockbuggy4x4
Re: '85 on steroids
Postby rockbuggy4x4 » Mon Jun 09, 2014 7:16 am
finally getting started on this project. very slow start but i got the drivetrain out of the red truck. trying to find poly bushing for the rear leafs and shackles. anybody have and sources? im going nuts here. :bh: :grrr: ill get some pics up once i steal my gf's camera. (
lost mine)
Jimmy
rockbuggy4x4
Re: '85 on steroids
Postby JeffTheMarine » Tue Jun 10, 2014 8:07 pm
I recently finished a swap on my crew cab so if you need any help or have any questions feel free to give me a call.
Jeff
208-EightSixThree-7411
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
Re: '85 on steroids
Postby rockbuggy4x4 » Tue Sep 30, 2014 9:35 am
Sorry for the late reply but thanks for offering your help. lol I finally got the rear taken care of for the most part. decided to stick with the 6' bed for now. Went with all new polyurethane bushings.
made some 3" spacers
boxed them most of the way on the inside for extra support
had an extra 36x12.5R16.5 laying around.
Jimmy
rockbuggy4x4
Re: '85 on steroids
Postby PToombs » Tue Sep 30, 2014 5:33 pm
I think you need a few more leaves in the springs, they look a little thin........... :lol:
Re: '85 on steroids
Postby ellis93 » Tue Sep 30, 2014 6:02 pm
PToombs wrote:I think you need a few more leaves in the springs, they look a little thin........... :lol:
I was thinking the same,or along the same, right after the holy schit I let out. Secretly I lust after them tho :lol: I bet you could drop more than a few tons in the box and not see it move :lol:
Good for doing REAL work ;)
Re: '85 on steroids
Postby rockbuggy4x4 » Wed Oct 01, 2014 3:31 pm
lol I know right? The red truck used to be a dumptruck.......or says the previous owner. :lol: I got quite a bit of work done on it today but now I'm having second thoughts on which axles to use. Ford Dana 60 Kingpin.....OR.....'92 and up Dana 60 ball joint?
I got both sides done. everything from the pitman arm down is off.
Jimmy
rockbuggy4x4
Re: '85 on steroids
Postby thrashingcows » Fri Oct 03, 2014 8:34 pm
Lots of work for you there...but will be worth it in the end. I did my2wd to 4wd conversion last year on my crewcab from Oct-May.
I have to ask what a ball joint Dana 60 is? To my knowledge all Dana 60 front axles are king pin units.
thrashingcows
Re: '85 on steroids
Postby CumminsPower59 » Sat Oct 04, 2014 7:10 am
Later Ford D60's (85 and up) used ball joints, pre-79, they were kingpin. 94 on up Dodge D60's used ball joints, and axle disconnect (up to about 00-01ish). Both are left side diff units.
Either way, if you are using Dodge drivetrain and suspension components, i.e., spring hangers, right side drop transfer case, just use a proper D60 axle...as pre-93. If you are four linking it, use whatever.
Re: '85 on steroids
Postby rockbuggy4x4 » Thu Oct 23, 2014 10:49 am
I'm going to be using a mix of parts. Lots of work and custom parts. I just ordered the joints/bushing as well as tubing for radius arms. I'm going to use the old coil springs for now till I get some with a higher weight rating. There's a few E350 powerstokes sitting at a local junk yard that I might grab the springs from. Transfer case (hopefully a Ford NP205) is on the shopping list.
Jimmy
rockbuggy4x4
