1979 dodge warlock
1979 dodge warlock
Postby ssd » Tue Oct 15, 2013 9:36 pm
Hi everyone this is my first post and I am hoping that no one has asked this very same question.
I was wondering if you guys could give me a heads up on what is too be expected with the project that I am wanting to do. I have 1979 Dodge warlock with a 360 and a 727 trans with what I think is a 203 transfer case. full time 4x4. I have found a air to air cummins I think that it came out of a 97 or 98 dodge. Question is will this cummins bolt into my drive train? I know I will have to beef up the 727 from what I have read and maybe an adapter plate. But I can't see not swapping this out I have found the motor for a really good price and the gas milage on the 360 sucks!!! I was hoping for at least 15-18 mpg out of the cummins. what do you think?
This is a really nice truck and I think that it would be cool to put a cummins in it! I can post some pics if you guys want to see the truck.
Thanks,
Shane
ssd
Re: 1979 dodge warlock
Postby ssd » Tue Oct 15, 2013 10:30 pm
This is the only pic I have off it right now but I can take more tomorrow.
ssd
Postby dazedandconfused » Wed Oct 16, 2013 2:56 am
No the Cummins has a specific bell housing. You will need to find a 727, 518 or 47rh.
Postby RumbleFish » Wed Oct 16, 2013 5:51 am
Youre also gonna want to beef up the axles. That 44 wont like the added weight for too long. Fwiw, i can pull 22mpg highway with my club cab 4x4. 18 should be easy for you. Good looking truck!
Postby ssd » Wed Oct 16, 2013 7:32 am
So will the gasser 727 tranny bolt on to the Cummins? I read all over that people are using them for the cummins but I can't find the diff. between a stock 727 gas and a stock 727 diesel.
ssd
Postby dazedandconfused » Wed Oct 16, 2013 7:37 am
ssd wrote:So will the gasser 727 tranny bolt on to the Cummins? I read all over that people are using them for the cummins but I can't find the diff. between a stock 727 gas and a stock 727 diesel.
dazedandconfused wrote:No the Cummins has a specific bell housing. You will need to find a 727, 518 or 47rh.
No the gas trans won't bolt up.
Postby dazedandconfused » Wed Oct 16, 2013 7:38 am
Very sharp truck by the way.
Postby RCCUMMINS89 » Wed Oct 16, 2013 4:51 pm
Nice truck
Postby ssd » Wed Oct 16, 2013 5:04 pm
yeah it is super clean, fresh rebuild inside and out fresh paint and the whole nine yards. We just got done with it at the beginning of the year. I am very proud of it minus the gas milage lol...
ssd
Postby ssd » Wed Oct 16, 2013 5:06 pm
Thank you
ssd
Postby JimmieD » Fri Oct 18, 2013 9:42 am
Best bet in the long run in many cases is to try to find a wrecked or rusted out CTD donor truck so you have all the needed drivetrain parts in one factory package.
Otherwise a 47RH trans, good diesel spec'd torque converter, adapter plate if engine or trans doesn't already have one, upgrade axles, beefier u-joints, driveshaft to fit, proper motor mounts [MANY options there], upgrade springs to handle the considerable extra weight, clean out the fuel tank and run larger fuel and return lines to feed the diesel [can use current gasser ful line as your diesel return line], preferably an air/air I/C, exhaust system upgrade to 4", added gauges like pyro and boost. Pyrometer can be the difference between a happy diesel or a very quick diesel death so it's best to install one right from the first.
It's a pretty large project overall and with all the change$ required you can see that it might be best to buy a donor truck.
Diesel's lower rpm range calls for an o'drive trans to be happy at highway speeds.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby dazedandconfused » Fri Jan 03, 2014 1:49 pm
Did you ever decide if you were going to convert it?
Postby ssd » Fri Jan 24, 2014 12:05 am
Yes I do plan on doing this conversion just looking for the donor truck, far and few between where I live in Eastern New Mexico.
ssd
Postby JimmieD » Sat Jan 25, 2014 12:06 am
You'll have better chances and probably much better prices looking for your Dodge Cummins donor truck over in Texas.
'90 W-350 gasser...
JimmieD
Postby Gregjy » Sat Mar 14, 2015 7:25 pm
Did you ever do the swap on the truck? I am currently doing one myself. It will probably debut at SEMA this November.
Gregjy
smoke screw?
Users browsing this forum: No registered users and 82 guests
