1992 d250 convert to 4wd
Re: 1992 d250 convert to 4wd
Postby simplysmn » Sat Dec 21, 2013 9:09 pm
Hey Bill I have a set of templates if you would Like a copy of them PM me .
simplysmn
Postby Diesel » Fri Feb 14, 2014 7:41 pm
simplysmn wrote:Hey Bill I have a set of templates if you would Like a copy of them PM me .
Hey if you would be interested in selling another set of templates I would love some.
1991.5 D250 Intercooled A518
Diesel
Postby Diesel » Fri Feb 14, 2014 7:45 pm
coalroller1 wrote:well kinda, I cut the section of frame off but didn't use it as a template, instead I clamped a sturdy piece of cardboard onto it, and traced all the holes out with a sharpie, then sharpened a 1/2" piece of copper tubing and used it has a hole punch to trace them out on the frame nicely
I want to do my swap like you did. To be clear you needed to bolt in a 4wd front crossmember that accepted the leaf springs? And you put some stock blocks in the back? I wonder if my 1991.5 would have the front leaf bracket holds on the stock 2wd crossmember.
Diesel
