new Ramcharger project
Postby coalroller1 » Tue Mar 11, 2014 1:47 pm
Hey everyone, I finished my 4wd swap on the '92 and sitll have the 12valve left over from the donar truck
I picked this guy up the other day for $1500 its a 4spd 318:
the 4spd has the clutch slave on the passenger side which I found weird, now my question is what trannys could I find easily?
it seems there are a lot of chevy nv4500's around, but what setup should I get considering availability cost, and if the transfer case I use is driver or passenger side output should I find ford or dodge axles
Thanks!
2006 volkswagen jetta gli 2.0tfsi, 6 spd, fuel pump 3" turbo back exhaust stage 2 goodies
1992 d250 converted to 4x4, 5spd getrag, 3.07 running gears
coalroller1
Re: new Ramcharger project
Postby dazedandconfused » Tue Mar 11, 2014 2:20 pm
That looks like a pretty solid rc.
Postby CumminsPower59 » Wed Mar 12, 2014 11:52 am
The stock slave positioning is a moot point, get yourself a proper Dodge NV/Getrag and 205 combo. Run Dodge axles as they are basically bolt on, as ford axle perches are different (wider) and the front driveline is on the other side.
Postby RCCUMMINS89 » Wed Mar 12, 2014 1:27 pm
It is more expensive up front.... but will save you a ton of money in the long run, if you get a full running driving donor truck. If you look long enough and hard enough you should be able to pick one up for $3000.
In fact in my area there is one today that is up fro $3000. 5-spd, 4x4, std. cab.... it is cheap because it is "non drivable, as it has a cracked frame at the steering box.
