Hey guys I found a 05 rolling chassis that I want to set a extended cab 1st gen on it and use the 3rd gen power train and brakes and everything. any idea what I will need to make the plan work? What will be required to make the engine run? I am going to go with a NV5600 and a south bend dual disc clutch. For gauges I am going to have to get a wiring diagram from the first gen to try and make as much as possible work, I do not think it will be a problem as it is mostly very simple direct connection wiring instead of the new modern communication and ECM, BCM, etc.
Thanks
Brad
