Rebars E350 Turbo upgrade
Postby rebar » Sat Dec 20, 2014 9:04 am
Hi Guys.. :)
Its been a while since Iv posted here and I almost forgot about the forum actually. I bought a E350 with a intercooled 1990 6bt installed. Tried to tow with it and took out the head gasket and main bearings.. A year and more grey hairs later its running like new again.
So this E350 a completed project, but I want to insure that next time I tow my 8k# toy-hauler, it has enough power to keep me cruising happily 65 mph.
I made the mistake of taking the PO's word about towing performance and didn't do a shake down run and hooked on and headed to Colorado loaded. I immediately noticed that shifting into 5th at 55 mph took allot of effort from the setup and I was down shifting on many longer grades even on the plains. My egt's sky rocketed and I had to feather the throttle constantly to keep my egt's in check, so plenty of fuel available. In hindsight, I feel my head gasket had already failed before I left, but it reared its ugly head after I made it over Monarch pass in 3rd and I started getting allot of white smoke.
I like the 28 mpg unloaded mpg the VE, 5 speed, 3.54, 32.5" tires gives me. But felt my gearing wasn't ideal for 11 mpg towing. Yes my H1C is laggy with the 18 cm housing, but I'm a little hesitant to fool with it even though I couldn't get it to light in 5th hardly while towing. Iv taken some advice over on another forum and got my hands on a 12 cm wg housing to spool quicker. My problem now is that I cannot mount that 12cm housing without using manifold studs, which forces me to install the manifold and turbo already bolted together due to van space constraints. I also have a 16cm non wg on the way which allows the use of bolts instead of studs. But not sure if a 16cm over my 18 will get me over "the hump".
Anyway.. I figured Id post over here just to see what some of you might suggest .. But my intiall thoughts were to improve my intercooler and piping to try and retain the mpg I was getting but I cant find any IC which will fit the van without building new endcaps.
Newly clocked compressor for new straight hot pipe requiring a spacer. Work in progress
1990 block, 1993 IC head, 5x12" , H1C 54-60-18. VE pump, nv4500 3.54 D60 FF
rebar
Re: Rebars E350 Turbo upgrade
Postby oldestof11 » Sat Dec 20, 2014 9:58 am
I personally love my HE351. Now that being said: Are those Canadian MPGs?
Have you tried a universal cooler? Like the Frozen Boost ones?
Postby rebar » Sat Dec 20, 2014 11:23 am
oldestof11 wrote:I personally love my HE351. Now that being said: Are those Canadian MPGs?
Frozen Boosts IC's are the same size as my 1st gen IC sprinkler plus the connections are in the wrong place. Nice prices though.
I wonder if the HE351's compressor clearance would allow me to clock it in the downward location I need, without manifold clearance issues like I have now?
My idea was to find a 2009 dodge IC as they were the same 1 1/2" think as mine, but larger, and cut off the end caps and fab new ones with the connections 3" higher to match my existing location.
The general consensuses in other parts is I need the 12 cm housing. I'm going to try the 16 cm first since it allows the needed bolts and 1/2" T3 spacer I need to clock the compressor down. If the 16 doesn't perform well I might have to weld the T3 spacer on the manifold because I cant get the longer bolts in a waste gate housing.
I swear that's the mpg hand calculated from the 1100 mile trip back with a heavy foot.
rebar
Postby cmann250 » Sat Dec 20, 2014 3:06 pm
Why not put studs in the top manifold holes? Isn't that a regular truck manifold flipped?
Postby CumminsPower59 » Sat Dec 20, 2014 4:27 pm
I spy Hawkeye state plates! Where abouts? Can't quite make out the county on the plates, appears to be Henry County...
