I have overhauled the whole front axle area- (4 wheel drive) and brakes.
New stock ford clutch. Has 6 speed ZF-6 - 3.73 and 33 inch tires. (from previous owner) and 6 inch lift.
May lower it some later- maybe
Truck has about 175k miles ( ex-6liter) and engine has about 50K.
once engine is in - will build new trans. crossmember.
Doing new 60 lb valve springs, new head gasket- head studs- 3200 gov. spring..... correct paint-
maybe upgraded turbo- ( has h1c)
probably build a 5 inch exhaust.
Hope to get GOOD mileage. (25 at least)
Will be a work truck and all round utility truck. should go up-hill in the mountains without puking- like most cars.
(thanks for everybodys help here too !)
cheers-
tim
