popular alternator upgrades ?
Postby jethro » Sat Jan 30, 2016 11:44 pm
I am about to try hooking up my dodge alternator with an external dodge regulator and see if the darned thing works.
If the alt happens to be bad- or just doesn't make enough current to break even (charging) - what is a popular
and available higher current alternator that is drop-in ?
have read about one called - delco remy 24SI with hinge mount- supposed to come in 160, 180 and 200 amp versions.....
Are there other popular ones being used ?
Tim
jethro
Re: popular alternator upgrades ?
Postby CumminsPower59 » Mon Feb 01, 2016 12:57 pm
When the one on my pile quits, this is what I am going to go with...
http://www.dieseltruckresource.com/foru ... ns-247286/
Postby JeffTheMarine » Mon Feb 15, 2016 4:34 pm
The article referenced above is about the best option in my opinion. After dealing with multiple charging issues with mine (Mopar voltage regulator related) I decided that when this one goes out I am going to with a similar setup however I am going to use a Delco remy 21SI alternator. I talked with a local automotive electric shop and they suggested the 21SI. A decent automotive electric house can get you the 21SI with the correct pulley so you don't have to modify one like in the write up. The highest amperage I have seen the 21SI in is 240 so a lot higher than the leece neville I believe.
Jeff
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
