flat air filters for 5.9 ?
Postby jethro » Sat Apr 23, 2016 9:39 pm
I am trying to finish up the fummins......
Got a BHAF air filter early on- but maybe too tight on the passenger fender well to fit it---- without
cutting up inner fender well---- 9may have to do that-)
Has anyone tried something like the largest size of flat type disposable paper filter ?????
Would be easy enough to build an aluminum box and lid for it........
just don't know if a large flat filter would flow enough and not have resistance.......
Any experience ???????
Tim
jethro
Re: flat air filters for 5.9 ?
Postby BILTIT » Sun Apr 24, 2016 9:16 am
3rd gens use a flat filter, maybe check them out?
Derek B.
BILTIT
Postby jethro » Sun Apr 24, 2016 6:42 pm
Thanks Biltit- I did not realize that ! I will check that out !
Tim
jethro
Postby thrashingcows » Sun Apr 24, 2016 10:11 pm
Keep us posted if you find something that works.
thrashingcows
Postby BILTIT » Tue Apr 26, 2016 10:44 am
Derek B.
BILTIT
Postby jethro » Sun May 01, 2016 11:36 pm
ended up hacking out a saddle shaped hole in inner fender well to use the BHAF- the flat one was all most as expensive
and only half (or less) surface area......
Tim
jethro
