'91 D-250 Resto Thread
Postby meby » Tue Feb 21, 2017 1:22 pm
I've just got my '91 running again. It was parked for two years for a couple reasons one of which is the cab floor and rocker are in terrible shape. I have a pristine cab that's going in for paint next week that will go on the truck.
Can I use the cab mount bushings for the 85' and older trucks? Seems like read they'll fit , but can't find the thread discussing them.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: '91 D-250 Resto Thread
Postby PToombs » Tue Feb 21, 2017 3:45 pm
IIRC they are the same. I put Polys on mine, and hate them, but some of the NOS ones are nonexistent.
Postby meby » Tue Feb 21, 2017 5:14 pm
PToombs wrote:IIRC they are the same. I put Polys on mine, and hate them, but some of the NOS ones are nonexistent.
To rough?
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Tue Feb 21, 2017 5:48 pm
Every bit of vibration comes right thru them. For a long time I thought I had a bad u-joint, but I'm getting of the opinion that it's just the mounts transmitting vibrations from the engine or tires or something.
Postby meby » Thu Feb 23, 2017 5:45 pm
Got my cab mounts and dynamat today. Gonna see how quiet I can make one of these trucks.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Tue Feb 28, 2017 10:21 am
Edit: Photobucket sucks!!!!!!!!!!!!!
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Tue Feb 28, 2017 12:22 pm
Before:
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Tue Feb 28, 2017 12:46 pm
Almost have the cab off.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Tue Feb 28, 2017 6:28 pm
Ohhhhh, yes, I agree with that! I get at least 1 and as much as 3 posts from Pb a day. I've marked them as spam, and keep dumping them in that folder and they keep coming. They did some kind of an update a while back, and since then it's awful.
Making progress on the truck though!
Postby meby » Sun Mar 05, 2017 7:19 pm
Got the cab off, the frame cleaned and most of my replacement parts like door and window seals and carpet etc ordered.
Pete...I think a couple years ago you told me that some later model stereos would fit our trucks. Do you happen to remember which ones fit?
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Mon Mar 06, 2017 5:48 pm
Everything up to '01 Bud! I have AM/FM/ Cassette/ CDs in both trucks. $20 or $25 from the junkyard. ;)
Postby meby » Mon Mar 06, 2017 6:06 pm
Thanks Pete!
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Mon Mar 06, 2017 6:07 pm
Is that heavy enough for a cab mount? It's 3/8" thick. Or should I weld some bracing across the ends.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby Philip » Mon Mar 06, 2017 9:54 pm
Mat that's more than thick enough. If your mounts are rusted out where the rubber sets. You can weld a large washer in also.
This in one of my front mounts I repaired.
This is a rear mount with flat washer in it.
Postby PToombs » Tue Mar 07, 2017 5:25 pm
No problem Matt!
I repaired 3 or 4 of mine like Philip did, they came out good. No problems yet!
