1984 Dodge D350 SRW Crew Cab 4x4 Question
Postby Collers9640 » Mon Apr 10, 2017 9:40 am
Does anyone know what 4x4 truck I should use to convert mine. Im wondering if there's a certain year that would have holes line up with the D350 frames' predrilled holes.
Collers9640
Re: 1984 Dodge D350 SRW Crew Cab 4x4 Question
Postby simplysmn » Sat May 20, 2017 10:08 pm
Best bet is if your going Diesel stay away from 91.5 yr truck's .I stay with the 92.93 dodges and it makes it nice .Once you convert the truck to 4x4 it's Pretty simple . Get a donor truck that is 4x4 and cut the frame off at front cab mount trim it down to a flat plate then bolt it up against the frame Mark and drill your holes .and as for trans No the holes won't line up .doing a 4x4 conversion you end up drilling roughly 40 holes 1/2 each .Message me if you need any thing else .Crewcab's is what I do .
simplysmn
